Question about Breadman TR850 Plus Bread Maker
Mixing basket pops up during kneeding - Breadman TR850 Plus Bread Maker
Bend the clips on each side of the machine in towards center with a screwdriver while the bread pan is removed from the machine.
Posted on Jul 13, 2008
  • Ally B Dec 05, 2010
    I tried this many times, thanks. In the end I contacted the manufacturer who was unhelpful and said it was the only way of securing the pan. I told them about other manufacturers methods (eg lightbulb style twist!
    In the end, I passsed this on and bought a different make!
Filter basket door opens during coffee making.
sounds like there is a bad relay, that is shorting out, and releasing the filter basket accidentally. Also, check to make sure that there is nothing blocking the latch that holds the filter basket in place.
Feb 05, 2008 | Cuisinart Thermal DGB-600 Grinder
Paddle won't turn properly while kneeding
does the pan turn at all while kneading? Does in knead at all?
Feb 03, 2013 | Oster Model 5812 Bread Machine Loaf Pan...
The machine is clicking but not mixing and kneeding
sometimes it takes 20-30 mins for machines to get to the right temp before they start mixing.
Jan 22, 2011 | Cuisinart CBK-200 Bread Maker
Need a mixing blade for ABM3500
goto the amazon website its called a kneeding balde there about £6.05
Jan 17, 2011 | Welbilt ABM3500 Bread Maker
When kneeding dough by the time the last of the flour is added the mixer does not have enough power to kneed it. A year ago it did but has gradually lost power. I have taken the gear head apart and...
HI KEN9486, from the way you describe your mixer’s malaise, the apparent lack of power during the dough mixing process does not appear to be to be a mechanical issue, but electrically induced. You’ve already put your fingers on the culprit – the brushes! Anytime your mixer’s brushes have been worn down as much as you indicated, they should be replaced.
Be sure you have the Parts List manual on hand to order the correct brushes. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) but check to verify this matches your mixer model.
On Pages 6 and 7, you will find the brush & spring assembly (Illus. No. 29) and Part No. 9706416 that you need to order. Replace them both.
Here are five potential online vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping.
I think you’ll find new ‘life’ in your mixer after you’ve replaced the brushes and it should be able to handle dough mixing without further problems. Good luck, I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Feb 25, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Kenmore washer model 110.23812100. basket not spinning during spin cycle.
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23812100
Also see the Whirlpool Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If you can hear the motor and the washer drains during the spin cycle the Motor Coupler and Lid Switch (the usual problems with these washers) are not the problem.
These washers use a clutch which allows the "basket tube" to spin up to speed during the spin cycle.
If the clutch bands or springs are worn or damaged, the transmission cannot transmit power to the basket tube for spining.
See the following on how to remove the cabinet,agitators, basket, pump, transmission and basket tube. (It's not as difficult as it sounds.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Instead of using a special spanner wrench on the spanner nut, I've used a short 10" pipe wrench hooked onto one of the tabs on the nut and tapped the handle with a hammer to loosen the nut. I also put a short piece of wood under the Basket Drive Block and hit the wood instead of the drive block directly.
Check the clutch bands and springs and the tabs on top of the basket tube and the slots in the basket drive block.
Nov 03, 2009 | Kenmore Washing Machines
When the dough is kneeding, the pan unseats from the machine and pops up off of the bottom stopping the kneeding process. Does anyone know how to fix this problem. I may need one of those black (I dont...
most of the time you will need a pan . the paddle berrings are freezing up and to keep the motor from burning up it is set up to pop the pan up .turn the paddle from underthe pan and from inside the pan it should turn real easy if not theres your problem
Mar 08, 2009 | Betty Crocker Kitchen Appliances - Others
Filter pops out in middle of cylcle
I periodically take a wet Q-Tip and clean around and inside the "slides" for the brewing basket door, so that it slides in and out easily. (I was amazed what the Q-Tips look like after you do this.)
I think the problem lies in the fact the basket does not go fully back and engage the latch due to the gunk that builds up on the slide. You think you fully closed the door when you feel the resistance of the gunk, but you are only marginally latched - the vibration of the motor pops the door free and VIOLA! coffee-ala'-counter!
I think the gunk comes from very fine ground coffee dust, mixed with water that condenses from the steam that envelops the unit during brewing.
I also clean every surface in the brewing basket area with a wet paper towel,
Mar 24, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Breadman TR850 Plus Bread Maker Logo
73 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
