Question about Lenovo 3000 N200 T7100 1.8G 1GB 160GB SYSTDVDRW 15.4-WXGA WL BFP XPP PC Notebook
BIOS Beeps Hiya i had the three bios beeps, and i removed and reinserted the memory as you said online. There is no longer any beeps, but now there is no screen appearing :S So what do i do now???? Cheers, Tom (Reply to : Tom_cowes@hotmail.com)
    Sergeant:
  • 324 Answers
Hey there Tom! Sorry for the slow response, but have had too many irons in the fire at the same time, as of late.
Sounds like you may have a case of , what I call "RIC" (Repair Induced Confusion).
Nothing to be ashamed of. We all experience it from time to time, whether novice or professional. I don't know if it is a fungus or bacteria, but I think that the manufactures' pour a little of it in many electronic devices. As soon as you open the cover to attempt a simple repair, you get the disease. Once you contract the disease, anything and everything you touch seems to turn to ****. From personal experience, I can say that it is reoccurring and once you get it, it will usually last the rest of the day, or until you get that item finally repaired ; which ever is longer.
It causes a person to not get things reseated correctly; or to plug things into the wrong place; or to unintentionally loosen a different connector; or to do things that make perfect sense at the time (but someone else would look at it and say "Boy,was that a dumb thing to do!")
Usually, the fix for this is to very slowly, methodically and carefully go through the entire device and reseat anything that is reseatable. Cables, connectors, hard drives, CD drives, memory, modules, batteries (excepting maybe, the CMOS battery) and so forth. While doing this, keep your eyes open and check for anything that shouldn't be there. I have had small pieces of wire, solder balls, used staples, extra screws and such creep from my work area into whatever I have been working on.
If this doesn't work the first time, take a break and try it again. Go get a cup of coffee, take a walk around the block, go out and mow the lawn. Then set down and try it again.
Hope this helps and best of luck!
Ron
Posted on Jul 28, 2008
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Jul 27, 2011 | Dell Dimension 9200 PC Desktop
Hi, just swaped out a harddrive now my Mainboard *4 core Duel Sata2* does a single beep, pause then rapid beeps. can you help
Please count the number of rapid beeps. 3 short beeps is a memory error. 8 short beeps is a display memory error. 9 short beeps is a ROM Bios checksum error and 10 beeps is a CMOS shut down read/write error.
The solution will depend on the error. For a memory error, remove all of the memory sticks then reinsert each one separately and reboot the computer. If the board continues to beep 3 times, that stick is bad or the memory slot has failed.
The complete beep code list is provided here: http://www.asrock.com/support/qa/TSDQA-01.pdf .
I hope this helps.
Mar 27, 2011 | Asrock P4I45GV R5 Motherboard
Ram beep but no display bios jumper is clear stat bios jumper is normal then no start machine
Please see this as reference
Continuous long beeps-RAM error
2 short beeps- BIOS error
1 long and 8 short beeps- Display Card error
1 long beep after few seconds 2 short beeps-FDC error
1 long beep after few seconds 1 short beeps-FDC is Ok
1 long beep and 2 short beeps-Display Card Error
Most probable cause is Ram memory, please try removing modules and reinserting, also try using alternately just one of them to determine which one is defective.
Mar 04, 2011 | ASUS P4GE-MX Motherboard
My computer beeps continuously every time i have it plugged in
Try this suggestion. Turn off your laptop, remove the cables and battery on the pc. Press and hold the power button for 8 secs. Then reinsert the cables and battery on the laptop and then turn on the pc. If it still continues to beep with no interruption, it is a problem on the motherboard. I suggest to call Acer and have your computer repaired immediately unless if you know how to reseat the motherboard by tearing down the laptop..
Jul 13, 2010 | Acer Aspire 5735-6694 Notebook
Loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
Jun 10, 2010 | Dell Inspiron Mini 10 Notebook
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
My sony viao pcg-3A1L will not power on it will only beep three times
Re seat the memory card and also take off PCMCI card if any and reboot.
Thanks
Oct 24, 2009 | Computers & Internet
Pc keeps beeping 3 times and nothing on the moniter
remove the RAM(MEMORY CHIPS) from *********** board and reinsert.if the problem is same replace the chips,get new chips.mostly cleaning the golden lines on the chip with pencil/school rubber solves the problem.
No beep is usually a power problem that can be related to the power supply, motherboard or both. Always check your battery power before thinking there is a bigger problem.
Step3
One beep is a normal POST. That means everything is fine. Two, Three, or Four short beeps are normally about the memory of the machine. If there is a problem with one of your memory chips you should get beeps of different combinations in this area. If you get two or three short beeps, one or both of your memory chips could be in trouble.
Step4
Five beeps point toward motherboard or CPU problems. Make sure your memory and video card are seated properly. Try removing them and putting them back in, only if you are comfortable with computers. Six, seven and eight beeps. Eight beeps indicate problems with your video card. Six or Seven are CPU, or a bad chip on the motherboard. Nine beeps mean the BIOS is bad. Replace the motherboard. Ten beeps means the problem is in the CMOS. All chips need to be replaced.
thanks.
Jul 11, 2009 | Asrock 775i65G Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
P5RD2-VM mobo will not post at boot
Three beeps for that bios is a memory error.Are you sure it's not a memory issue? Did you clear the CMOS and try to boot up again?
Dec 10, 2008 | ASUS P5RD2-VM Motherboard
Lenovo 3000 N200 T7100 1.8G 1GB 160GB SYSTDVDRW 15.4-WXGA WL BFP XPP PC Notebook Logo
83 people viewed this question
Top Lenovo Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
