Question about MSI K8MM-V Motherboard
SATA DRIVER druing OS installation
HI ,I had fed up to use satafloppy for os installation .
help me to resolve this problem
  • laxman9 Jun 30, 2008
    hi igacek,
    in the process of operating system installation on sata hard disk
    every time i have to use a floppy(sata driver) on this motherboard.
    where as in other motherboards on sata hard disk we can install normally.this is my problem
  • 4 Answers
Your question makes no sense. Care to... elaborate a litte?
Posted on Jun 29, 2008
Is it possible to use ID harddisk and SATA harddisk at the same time?
You can indeed mix IDE & SATA drives on a computer. If installing the OS (Operating System) to the IDE HD, you will only need to instruct the BIOS to boot the IDE HD drive first.
If you decide to install an OS on & boot the SATA drive first; you will need to instruct the BIOS to boot the SATA drive first and may need to provide a driver for the SATA controller - if the OS install does not recognize the SATA drive. The driver should have been included on a disk or diskette with the controller (or on the motherboard driver disk if a built-in type controller). You should see a prompt asking "If you need to install a driver.... press F6" (or similar). Press the F6 key and supply the driver disk - and follow the prompts.
Nov 24, 2011 | ASUS K8V-MX Motherboard
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
My dell is showing a blue screen
hi there,
try to check laptop with new ram if same there is a issue of sata driver or another driver install in your os re install os(oprating system)
Jul 11, 2010 | Dell Inspiron 6400 Notebook
I have a Lexmark E120 and I am using it with a Mac OS X 10.4 When I try printing the green light blinks and the rotators rotate + I get a "completed task" message on Printer Manager BUT no paper gets fed...
Hello, Uninstall the Driver from your Mac and download the following driver online. and install it. That should resolve your problem. Take into account that this is only for the Lexmark E120n if you have the Lexmark E120 then there are no drivers for Mac OS 10.4.
Dec 02, 2009 | Lexmark E120n Laser Printer
I have using vista os with my pavilion dv6000 entertainmen laptop
Hi there.
What you want is the intel matrix storage manager for theextra drivers so XP install can see the SATA drive. Download it fromhere and please make sure you read the read me text on how to set it up*+XP+Professional&lang=eng&strOSs=44&submit=Go!
Good luck and thanks for using FixYa!!
Apr 09, 2009 | HP Computers & Internet
Winxp instalation
There is not way to install a windows xp os without SATA drivers. If you don't want to use the floppy disk to make the os recognize the HDD, you can integrate the drivers in the Windows Xp installation Cd, using software like Nlite.
Another solution is to use a IDE HDD, the old kind with the 80 wire ribbon cable.
Mar 31, 2009 | VIA ASUS A7V600X MB AMD KT600/ 400FSB/...
Unable to Downgrade vista OS to windows 2003 or XP(CQ-LAPTOP)
During the Windows XP install it cannot find a hard drive?
The reason why Windows install does not work is because Windows XP does not have a SATA driver support and therefore cannot find the hard disk.
Go into your BIOS and turn off Native SATA support or set it to IDE controller (this setting depends on the type of BIOS). Save the setting and reboot and you will be able to install Windows XP.
Go to the Compaq/HP WEB site to download the SATA driver for your model laptop. This driver is used to install the 3rd party driver
during the Windows installation (during the Windows installation you need to press F6 to allow you to install the SATA driver).
Mar 30, 2009 | Compaq Computers & Internet
Sata driver
have you installed os in ur laptop?
if you are trying to install new os in your laptop(for first installation) go to cmos setup and you will have make none in your sata hdd option i m sure you will be able to install your laptop
Nov 07, 2008 | Compaq Presario 700 470024-192 Notebook
Cannot install Windows XP,Vista on Compaq Laptop(FreeDos) V3607TU.
I have two solutions for this problem. the first one is to change the bios settings. the solution is here:
but for some laptops this setting is not available. so you can try another solution i.e. integrate the SATA drivers in your windows XP cd. this solution is here:
Mar 23, 2008 | Microsoft Windows Vista Ultimate Edition
MSI K8MM-V Motherboard Logo
77 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
