Question about Bosch Axxis WFL 2060 Front Load Washer
Bosh Washing Machine leak
Have you managed to resolve this?
  • Reginaldg Jul 02, 2008
    Many Thanks i am monitoring mine as well, rather irritating though i must say, have to clean up the washroom floor after each wash.
Regildg,
No, I have not fixed it. I can see the water dripping off what appears to be electric motor plates hanging low on the bottom of the washer.
It does seem to leak most right after I have used the machine.
The drip is not getting worse and appears to be about the same.
Posted on Jun 30, 2008
L have a Bosh washing machine and l am having anE17 on the screen can you please tell me what the problem is?
please go onto the Bosh website for a user manual there usually free to download eric
Dec 22, 2017 | Washing Machines
Bosh classic washing machine fault no F 21
Kindly read the manual or see a specialist.
Jul 21, 2016 | Washing Machines
Bosch washing machine manual in english
Bosh has several washing machine models. you can search for it here
Download instruction manuals
If you can't fin your model's manual at Bosch website, as heroic last resource you can do a google search for it, input
Manual Bosch the model and washing machine
Be caerful with scammers promising to sell you a manual. Sometimes they only send some incomplete scanned paper with some advertisement about the product or affiliate yo yo an "ebook club" and start charging you monthly fees for sending you undiscriminated and mostly useless ebook files
Aug 09, 2015 | Washing Machines
Bosh neither spin nor drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
My Bosh washing machine has excessive vibration according the the level i put on the top of the washer it is level, but still seems to walk accross the floor on the final spin cycle.
it may be level but if the feet are not adjusted to be tight to the floor this will cause it to walk so try adjusting the feet then lock the locking nut I am sure you will find 2 that are not adjusted tight enough.
Feb 05, 2010 | Washing Machines
Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Sep 28, 2009 | Washing Machines
Hi, I have Front loading BOSH Classixx 5 washing machine purchased last week. But i dont have operating instructions in English. I need operating manual of this washing machine in english. Kamalnish
simply go back to the shop it was bought in and they have to supply with the instructions in english at your request at no further charge,email bosh at there customer services they will gladly supply you free of charg.adrian
Jan 10, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosh error code E02
Hi. I had the same problem with my Bosch washing machine and called Bosch...was told the same thing...$99.00 for service call. I managed to fix my problem by doing the following:
  • Removed hot & cold water supply hoses.
  • Took filter screens out of both hoses.
  • Removed filter from cold inlet on back of washing machine. I noticed some oily buildup on both of the cold screens so opted to not put any of them back in.
  • Then I put hot & cold water supplies back on the wall hookup, but crossed the lines where they came into the back of the machine intentionally so that the hot water line fed into the cold side of the washing machine and vice versa.
  • Then I ran a couple loads on "cold" which was actually hot water coming in to the machine.
The reason I did this was that I figured there must be some more waxy buildup inside the machine in the cold lines and hoped the hot water would melt it like when you rinse a greasy pan under hot water. IT WORKED!!! I hope this helps you.
Sep 29, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
142 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
