Question about HP Officejet 5610 All-In-One InkJet Printer
Paper jam i have a 5610 all in one, i keep getting a paper jam error but i removed all the paper and still keep getting the same error
  • Anonymous Dec 09, 2008
    wear do i get a new print mechanism if it is broke and how do i find out if it is broke?
  • pkpravin Dec 09, 2008
    I Have paper jam error. plz swolve this problem.
  • 31 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
334
Posted on Mar 19, 2009
    Novelist:
  • 106 Answers
sometimes, even we think that the jammed papers were already remove, there might instance that a pieces of paper stuck on the printer. i want you to follow the steps to somehow eliminate that message on your printer screen.
SOLUTION I:
1. press the power ON button to turn the printer off.
2. unplug the power cord from the back of the printer.
3. wait for 1 minute and plug it back in.
4. if you still have that "paper jam" message, continue to SOLUTION II.
SOLUTION II: CLEARING JAM PAPER
1. On the rear of the product, press in the tab on the left side of the rear access door to release the door. Pull the door away from the product to remove it.
CAUTION: Do not try to clear a paper jam from the front of the product. Doing so can damage the print mechanism.
2. Gently pull the paper out of the rollers if you see one.
CAUTION: If the paper tears while being removed from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the product. Loose pieces of paper will cause future paper jams.
3. Replace the rear access door. Gently push the door forward until it snaps into place.
4. Press OK to continue the current print job.
Note: If the issue is not resolved , continue to the next step.
SOLUTION III:
  1. Turn off the unit, then unplug the power cord.
  2. Press in the tab on the left side of the rear clean-out door to release the door. Remove the door by pulling it away from the unit.
  3. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around.
  4. Allow the rollers to dry completely, then replace the rear access door.
  5. Plug the unit back in and turn it on.
This time, try to print something.
Thank you so much.
best regards,
adonscott
Posted on Jul 03, 2008
Can't eliminate paper jam code
Follow this link may be it will help you..
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=bud09128
Apr 08, 2013 | HP Officejet 5610 All-In-One InkJet...
Printerwill not print it continuealy dispence paper then paper will jam
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Dec 29, 2010 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-in-One continuous paper jam,
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Am a service person i hav an office jet 5610 printer it always giving paper jam error what is reson for that
very often you get paper clips or staples that block paper path and therefore causes paper jam. also, some paper path sensors gets damaged and the debris can cause paperjam. I suggest you open all levers and check for foreign matters. You can even put the printer upside down so that the foreign thing gets out. The next step is to dsmantle everything and remove the fault.
Jun 08, 2010 | HP Officejet 5610 All-In-One InkJet...
I keep getting paper jam on my hp office jet 5610
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 02, 2010 | HP Officejet 5610 All-In-One InkJet...
My 5610 all in one series keeps telling me that there is a paper jam. I have checked and there is no paper jammed in the printer. It won't reset. It keeps saying paper jam. Help!
Check to make sure both ink cartridges are installed properly. I don't know why it says "paper jam" when the cartridges aren't properly installed, but it does.
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
My hp officejet 5610 all in one keeps saying paper jam and there is no paper jam
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab47
Jul 02, 2009 | HP Officejet 5610 All-In-One InkJet...
I have a hp 5610 that gives me an catridge jam error
its should be caraige jam ... remove the catridges try to move the caraige ... and hope that it doesnt move freely ... than check for any paper jams than put the cartridges again and see
Feb 01, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper jam
I have an HP 5510 All in one, and mine did the same thing. There was a plastic fingerlike thing that had hung up just to the right of the printhead, preventing it from moving. I removed the cartridge and managed to get the part unstuck with a screwdriver.
Oct 20, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
209 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
