Question about Praktica Roof Binocular
Praktica sport zoom 7-21x25
Sticky body, rubber degrading in some way, leaves dirty marks on fingers
  • 2 more comments
  • Clivespana Nov 30, 2008
    The body of my Praktica Sport 12 X 25 RC binoculars has a rubberised body and has gone extremely sticky to touch, anyone knows the cause or how to clean?
  • ellendale Jan 21, 2009
    I have the same problem - same model. These binoculars have been great, but now they are impossible to use.
  • conlan Apr 10, 2009
    i have the same problem how do i clean them
  • billtoynton Apr 23, 2009
    My praktica sport zoom 7-21x25 have become very sticky, the rubberised paint has become I think faulty.
    The answer for me was to stretch cling flim over the sticky parts.
    This is a tempory fix, I think, I whould have to replace all painted parts.
I have the same problem with my Nikon N65 film SLR and I bought a vintage Super 8 movie camera where the rubber had turned to the consistency of gum on a side-walk on a hot summer day. On the a camera I carefully rubbed on a coat of talcum (which probably isn't the best thing to use on a camera but I was careful and it isn't something I do every day). I then took a small square I cut from an old terry towel and used friction and elbow grease to rub off the top layer of the rubber. I then took another square of the towel and dipped it in hot soapy water, squeezed out the excess and washed all that remained. I then took a small water-colour brushed (after I dried the surface of course), and dusted the surface of the rubber with talcum and let it sit overnight. This seemed to stop the derioration and clear off what had built up. The next day I took a very dry damp towell (if that makes sense) and wiped off the surface. It pretty much took care of that problem. That was the Nikon, it was only in the beginning stages, the Super 8 camera which had apparently hadn't been out of the case in 20 years. The Super 8 was so bad that I don't even know what had deteriorated, probably a rubber eye piece, that one was time consuming but basically I put the powder on carefully and just wiped big clumps off the metal eye piece. The powder just served to make it easy to clean up and kept it from turning into a 3 stooges farce with one thing sticking to the other and so on. Well, I hope this helps, I don't know why it works, maybe there's a chemist out there that can explain it to me. Good luck!!
Posted on Oct 30, 2012
    Problem Solver:
  • 4 Answers
Don't need to do so many steps, after the powder drys up and sweatstarts to sit in, beconmes sticky again. go to this youtude it can be totally solve within mmins.http://www.youtube.com/watch?v=1oIe3SrcugE
Posted on Nov 14, 2012
The rubber body of my praktica binoculars have also become very sticky. My guess is it's the use of lower-grade rubber and the surface begins to perish over time. My solution was to clean the affected parts with acetone (nail polish remover), rubbing it on with a cloth until the top (sticky) layer of rubber had been stripped off. If you do a thorough enough job the surface should dry off smooth with no stickiness. The downside is it makes the rubber absolutely matt. I'm planning to coat mine with some kind of silicon based product afterwards to seal it and make the rubber more pleasant to touch.
Posted on Sep 14, 2011
  • 6 Answers
Purple Power Degreaser and Cleaner worked for me. Put binoculars vertical on a paper towel, spray them down, leave 10 to 15 minutes, wipe off the sticky junk with paper towels, repeat once or twice. Worked like a charm on my Bushnell 10*25. I wiped it down with alcohol as a final step (for whatever reason?).
Posted on May 26, 2015
How do i clean them
Posted on Apr 10, 2009
Sticky rubber drill handle
I would try wiping it down with some Goo Gone and see if that helps.
Aug 21, 2012 | Drills
Mouse Body Is Sticky How Do I Clean It?
I had the same issue and using clorox wipes only made it worse. I eventually used Lacquer Thinner, which is usually a mixture of solvents able to dissolve a number of different resins or plastics. It can be purchased at most home improvement or hardware stores. It worked perfectly.
It is a bit of a messy process and there are fumes. I wore rubber gloves and did it in my garage using several paper towels. I also recommend applying scotch tape to the edges of the non-rubber areas to protect the finish. Also avoid getting it on the bottom of the mouse.
Jul 26, 2012 | Microsoft Wireless IntelliMouse Explorer
Rubber housing on Sigma binoculars has gone sticky
  • Moisten a soft cloth with ammonia or Windex. Rub it over the sticky area to remove some of the damaged surface.
  • Ammonia can be used as well, but should be used with caution as it can cause damage to some plastic surfaces.
  • If the sticky, damaged surface remains, it can be scraped away with a spoon or dull knife.
  • Please note that these fixes are only temporary. Once the plastic starts to degrade, it will continue and the problem will be recurring. It is best to replace these parts whenever possible.
  • Nov 24, 2011 | Optics
    The rubber casing has gone sticky
    Many cameras and binoculars are covered with a sprayed on thin layer of rubber which breaks down after about 5 to ten years. It becomes very sticky and can be scratched off with a fingernail. This leaves a messy surface which can be cleaned off with methylated spirits. Other solvents will work like isopropyl alcahol but avoid using solvents like cellulose thinners or white spirit as this can attack the underlying plastic on some cameras.
    May 21, 2011 | Praktica Optics
    The battery cover as bowed i need to keep my finger pressed on the cover to take pictures if i dont keep my finger pressed on the battery cover the camera swiches off
    it seems the battery box are a little loose for the battery, you can add some thing(such as small piece ) between the battery and the box to let the battery and camera connect well. Don't block the joint between battery and box is OK
    Apr 25, 2011 | Praktica Cameras
    How do I get rid of Sticky legs on my OLD barbie dolls..... got them in the 80s and they have been boxed up in a tote. Now that my daughters would like to play with them I want to clean them first. But...
    They might be degrading unfortunately.... I too wanted yo revamp my old barbies for my daughter, but I think it may even be dangerous. As rubber breaks down it secretes oils and chemicals that can cause serious trouble. Eventually the sticky can turn to powder and can be inhaled...... Yuck
    Jan 15, 2011 | Toys
    Case is "sticky" like glue
    The same thing happened with my old Praktica Sport Zoom binoculars, and (in my case) found that the sticky coating could be removed by repeated rubbing with paper towels moistened with methylated spirit ("meths"). SAFETY FIRST: If you decide to try this method and have not used meths before, it is a very flammable liquid, and harmful by touch and inhalation, so please wear rubber gloves and do this outdoors or in a well ventilated place and away from sources of heat or fire. That said, it is cheap and readily available from DIY stores, usually in their painting section.
    May 09, 2009 | Optics
    The rubber armoring is "melting" or getting all sticky
    It can be easily resolve, just go to the youtude, check for sticky melting solution. The sticky surface can be treated and back to normal.
    Dec 11, 2008 | Bushnell Optics
    Can't open rear compartment
    To seperate the two body halves: 1-Set the vacuum on it's wheels & open the front door. 2-Place a wide screwdriver blade just between the reaer cover and the rubber bumper and tap the screwdriver on the side to push the bumper forward towards the door a little bit. 3-Grasp the bumper and pull it straight out. 4-Leave the vacuum halves together...flip the vac over on it's top. 5-Put your palms against each wheel with your fingers in between the body halves..pull each side out just a little and snap the lower body upwards. It will then come apart. 6-You can then mark the wires on the cordwinder for corresct replacement afer the repair. Make sure you put the bumpers back on each I-Beam before you put it back together. (they don't need to be removed). And the FLAT end of the rubber bumper is against the front door. Good Luck !
    Aug 30, 2007 | Electrolux Epic 6500 Vacuum
    Praktica Roof Binocular Logo
    3,664 people viewed this question
    Top Praktica Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    Mark Campeau
    Level 1 Expert
    Are you a Praktica Optic Expert? Answer questions, earn points and help others
