Question about Honeywell Heating & Cooling
I am trying to connect a Honeywell H46C Humidistat to a LUX 1500 thermostat. There are two wires on the Humidistat.
  • 2 more comments
  • rjcream Jul 01, 2008
    The wires connected to the thermostat from the main unit are G Y W RH with a jumper wire to RC , B and O terminals not in use. There are two wires on the Honeywell H46C Humisistat. To what terminals on the thermostat do I connect them to in order to be wired parallel or to get the Humidistat to work properly.
    I don't know.
    I will try the G and RC/RH connection later. Will get back if that does'nt work. Thanks
    Tried the G RC connection, but the A/C unit ran continually.
    Genius:
  • 1,665 Answers
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jul 01, 2008
    Connections and Operation
    A dehumidistat in combination with the thermostat can be
    used to run the air conditioner to control relative humidity
    levels. The dehumidistat and thermostat can be wired in
    parallel or in series.
    Wiring in parallel allows the dehumidistat to independently
    control the humidity level, but could cause
    overcooling of the home. During unoccupied times, the
    homeowner should set the thermostat to a relatively high
    setting and control moisture using the dehumidistat.
    Wiring in series prevents overcooling but the air
    conditioner runs only when both the thermostat and
    dehumidistat are calling. During unoccupied times, the
    homeowner should set the thermostat to a relatively low
  • 105 Answers
Www.airconnectweb.com.try this site to get more details on the doubt
Posted on Jul 01, 2008
    Master:
  • 382 Answers
Thermostat connetion pattern is as follows:
Red, hot side of transformer.
Common side of transformer (See B)
Yellow, Compressor activity (cooling or cooling and heating on a heat pump).
Green, furnace blower fan. (needed for air conditioning, heat pumps and some electric furnaces).
Orange , Energize to cool (used for reversing valve on heat pumps)
Blue or Orange, Energize to heat
    Master:
  • 497 Answers
Http://www.airconnectweb.com/links.php
do try this link
hope this works
tc
    Guru:
  • 1,894 Answers
Can you please tell me the input terminals for your thermostat?
    Genius:
  • 1,036 Answers
This is the manual for the LUX 1500 - Here
  • 2 more comments
  • Richard Perkins
    Richard Perkins Jul 01, 2008
    Sorry - slip of the mouse - Here
  • Richard Perkins
    To operate the fan, according to page 2 of the pdf - (4 wire) it's accross G and the RH / RC posts.
    I don't think polarity matters if it is purely a switch contact humidistat.
    This should power the fan on - to circulate air irrespective of temperature.
  • Richard Perkins
    Richard Perkins Jul 02, 2008
    Was the air humid ? if so it was only doing it's job.
    What effect did turning the humidistat up or down have?
  • Richard Perkins
    Richard Perkins Jul 06, 2008
    Please remember to rate best answer as Fixya! if it works.
    Thank you.
    Genius:
  • 2,035 Answers
Please use this link:
http://www.toad.net/~jsmeenen/wiring.html
Good luck..........
HONEYWELL RTHL2310/RTHL221 THERMOSTAT AIR WILL NOT COMEON
Recheck your connections.The wire colors may not have been wired in the standard way when HVAC system was installed. I remember the instructions on my Honeywell thermostat(replaced mine about 2 months ago) stated that you should look at the wire LOCATIONS on the 'stat you're replacing and tag the wires according to this,not the wire color(too late in your case).You'll have to verify the wires.Disconnect them(don't worry about noting where they were as it's not right anyway).Using an A/C voltmeter,locate the hot feed to the 'stat(ground one lead of the meter at a nearby outlet and look for 24v on any of the wires).Tag it as "feed".Now,touch this to each wire until you find one that turns on the ventilation blower and tag it.Try the other two,one of them should turn on the outside A/C condensor unit(this is the A/C wire).The remaining wire's gotta be the furnace,but verify anyway.This should be enough to get you back on track(don't feel bad,the instructions in my 'stat confused me a little,even though I've replaced mine a couple times before).PS- I think the blower fan wire goes to the terminal with the little factory jumper wire-this is so you can set it up to run the same fan in heat or A/C(factory setup) or remove the jumper to run a seperate fan for each(highly unusual setup but possible)
May 25, 2012 | Honeywell Programmable Thermostat Heater
Lost manual for lux 1500 thermostat
Visit this link LUX INSTALLATION AND OPERATING INSTRUCTIONS SMART TEMP ELECTRONIC THERMOSTAT TX1500
Also in this other: Lux 1500 Thermostat Instructions (PDF)
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | Cameras
I have an existing honeywell thermostat - 4 wire hook up. I added a honeywell humidistat. I hooked it up for series operation meaning when we leave the house in south Florida for the summer, the humidstat...
That 's a really good idea. My question would be is that a two wire humidistat? If it is. you would have to parallel the wires. One wire on the "R" on the thermostat and the other would go on "Y" and jumper to "G". Really interesting , I would like to know if it works. I live in Okla. and we have real high humidity summers but probably not like Florida. Hope this helps you.
May 14, 2011 | Honeywell Heating & Cooling
We have just had a Honeywell H46C humidity controller installed. The technician told us to set both the humidistat and digital thermostat at 65 degrees when we leave the FL condo for the summer. Is this...
If you are leaving for SUMMER, definitely do not need to set at 65, that would be tremendous waste of energy. Humidistat in summer should be off. I wonder if he thought you would be gone during winter.
Feb 04, 2011 | Honeywell Heating & Cooling
I recently installed a Honeywell RTH6350D to replace a 2 year old LUX and can get everything to work but the heat(reason for replacing the LUX). Works sometimes but not consistantly. Have the common red(R)...
R represents power supply for the heat system.
RC represents power supply for cooling system.
G represents fan (neutral).
W represents heat system.
Y represents cooling system.
Y2 represents 2nd stage cooling.
W2 represents 2nd stage heating.
AUX represents heat pump.
Try calling 1-800-468-1502.
Their english is "REALLY BAD"!!!
Jan 02, 2011 | Honeywell Electronic Programmable...
FROM A CONDO IN FL WITH HEAT PUMP---I HAVE A WHITE-ROGERS THERMOSTAT (2 STAGE HEAT-1 COOL) AND WANT TO WIRE IN A HONEYWELL H46C HUMIDISTAT FOR HUMIDITY CONTROL. THERMOSTAT HAS THE FOLLOWING WIRE POSTS E O...
It's a little unusual to add a humidifier in Florida. The ambient humidity is usually high enough.
But anyway, if you want to do this and assuming you have central air with forced air heating, you could install the humdifier in a standard configuration, then use a sail switch or differential pressure switch in the supply air duct to turn the humidifier off or on when you are in the heating mode only. The sail or differential switch will ensure that the unit can't run unless air is moving and you can tie the humidistat in to the first heat stage.
Mar 05, 2010 | Honeywell Power Humidifier: Furnace...
I am replacing an old Lennox thermostat with a new Lux DMH110 digital thermostat. My furnace(oil) has only two wires on the thermostat(heat only). I connected the wires according to directions of new...
Make sure on the furnace that you have the same colored wires connected at the thermostat to R and W. Check for good connections at both locations. You can always test to make sure the unit fires by crossing the two wires together. If the unit fires, you have a bad thermostat.
Feb 17, 2010 | Honeywell Programmable Thermostat Heater
Honeywell humidistat stuck
what i would do is make sure tha the hole for the wires that go to the humidistat is completely closed and that you are sensing the true humidity for the space also have the tech wire the so that the heat comes on instead of the ac for the de-hiumidification process.
Feb 10, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Wiring issue with the Honeywell HE360A Humidifier
Maybe I can help. this is 24v so it doestn't matter which wire goes where so here goes. 2 wires from humidistat go to furnace, split one of the wires(not both) so they reach the yellow wires on the humidifier. with marettsconnect one of the split wires to one of the yellow wires. do the same to the other split wire and yellow wire. what you should get is one wire from humidistat to furnace then one wire from humidifier to humidistat and one from humidifier to furnace. hope this helps
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
387 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
