Question about Maxi-Cosi Priori
  • 48 Answers
Contact the manufacture at
email Consumer Relations at, or call Consumer Relations at (800) 951-4113.
they can help
Posted on Aug 20, 2008
Trouble removing valve cover on the right side (passengers side) of the engine on a 1996 mark viii. Help
  1. Remove engine appearance cover retaining bolt and nuts.Remove engine appearance cover from vehicle.
  1. Disconnect engine control sensor wiring at intake air temperature sensor (IAT sensor) connector and crankcase ventilation tube from air cleaner outlet tube.
  2. Completely loosen air cleaner outlet tube to throttle body bolt (captured bolt).
  3. Loosen clamp on air cleaner outlet tube to engine air cleaner (ACL) and disconnect air cleaner outlet tube.
  4. Remove remaining bolt from support bracket clamp on RH valve cover to air cleaner outlet tube.
  5. Remove air cleaner outlet tube and engine intake air resonator.
  1. Remove two retaining nuts from engine air cleaner outlet tube bracket to valve cover and remove engine air cleaner outlet tube bracket.
  2. Remove four nuts retaining RH ignition wire cover and remove cover.
  3. Disconnect ignition wires from spark plugs with a gentle twist! pull motion on the spark plug boot. Remove spark plugs.
CAUTION: Do not pull on the ignition wire as it may separate from the connector in the boot.
  1. Remove bolts and studs retaining RH valve cover to cylinder head.
  2. Remove valve cover.
Sep 28, 2017 | Cars & Trucks
95Xi Crosstrainer Crank Arm Cover Replacement
About This Video
Crank Arm Cover Removal and Replacement Video for the 95Xi LifeFitness Crosstrainer
  • This video demonstrates how to remove and replace a Crank Arm Cover on a Life Fitness 95Xi Crosstrainer elliptical
Necessary Tools:
  • Philips Screwdriver
  • 5/32" Allen Wrench
  • 2MM Allen Wrench
  • T25 Driver
  • T50 Driver
  1. Remove the main shrouds as seen in the shroud replacement video
  2. Remove the outer link cover as seen in the outer link cover removal video
  3. Remove the pedal lever assembly (as seen in Sportsmith's Pedal Lever Replacement video) on the side where the crank arm cover replacement is needed
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Replace the parts in reverse order
LifeFitness 95Xi Crank Arm Cover Video Removal and Replacement
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover...
Removing the Unit Compartment Cover
NOTE: Sharp edges may be present.
1. Unplug the refrigerator or disconnect the
2. Lift the main decorative panel to unhook it
and remove the panel.
3. Lift and remove the louvered decorative
4. Remove the two hex-head screws from
the air diverter and remove the diverter.
5. Remove the nine hex-head screws from
the unit compartment front cover, and pull
the cover forward out of the way.
NOTE: If there is less than 3above the top of
the unit compartment cover, perform Method A
to remove the cover. If there is at least 3above
the top of the unit compartment cover, Method
B will allow you to remove the cover without
pulling out the refrigerator.
1. Pull the refrigerator out of its mounting
location so you can access the rear of the
2. Remove the left and right hex-head screws
(one on each side) from the front corners
of the unit compartment cover.
3. Remove the left and right hex-head screws
from the rear channels of the unit compartment
4. Lift the unit compartment cover up, and
pull it forward off the refrigerator.
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method B
KitchenAid, Whirlpool side by side refrigerator remove the main control board assembly
on Aug 27, 2010 | Refrigerators
How to replace 98honda accord valve cover gaster
Remove plugs..
Remove 6-8 bolts around cover..
Remove valve cover....
Remove gasket and clean cover...
Replace gasket and replace cover w all bolts..
Install plugs..
Aug 24, 2014 | 1998 Honda Accord
Change timing belt
timing belt? on a Jeep? 05 wrangler
what engine is this>?
ah the 2.4L
front cover
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove the crankshaft vibration damper.
  3. Remove the generator drive belt tensioner assembly.
  4. Remove the timing belt front cover bolts, and remove the covers.
rear cover
  2. Remove the front covers.
  3. Remove the timing belt.
  4. Hold the camshaft sprocket with Special Tool 6847, or equivalent, while removing the center bolt.
  5. Remove the timing belt idler pulley.
  6. Remove the rear cover fasteners and remove the cover from engine.
Apr 04, 2014 | 2005 Jeep Wrangler
Changing the fuser for a CM1415fnw
If your capable of searching google, you may want to grab the service manual for this, heres the procedure to change it out but as you can see there are even more procedures along the way...
Fuser 1. Remove the following components: ? Right cover. See Right cover on page 17. ? Right-front cover-1 and cover-2. See Right-front cover-1 and cover-2 on page 20. ? Control panel. See Control panel on page 22. ? Left cover. See Left cover on page 25. ? Document-feeder and scanner assembly. See Document-feeder and scanner assembly on page 28. ? Rear-center cover. See Rear-center cover on page 30. ? Rear-upper cover. See Rear-upper cover on page 31. ? Speaker. See Speaker on page 33. ? Top cover. See Top cover on page 34. ? Rear door and rear-lower cover. See Rear door and rear-lower cover on page 41. 2. Remove two screws (callout 1) and the black plastic cover (callout 2). Figure 1-117 Remove the fuser (1 of 4) 1 2 80 Chapter 1 Removal and replacement ENWW 3. Disconnect five wire-harness connectors (callout 1). Remove the wire harness from the guides (callout 2 and callout 3) and one retainer (callout 4). Figure 1-118 Remove the fuser (2 of 4) 2 1 3 4 4. Remove four screws (callout 1). Figure 1-119 Remove the fuser (3 of 4) 1 ENWW Removal and replacement procedures 81 5. Remove the fuser. CAUTION: Handle the fuser carefully. The sensors that are mounted to the output side of the fuser can be easily dislodged. When the fuser is reinstalled, make sure that the sensors are present, and correctly fastened to the fuser assembly. Figure 1-120 Remove the fuser Hope this helps...
Feb 16, 2014 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
How to remove casing
To make sure there is a clear understanding here's a complete diagram
Overall Parts Diagram
To Remove the Outside Plastics on the HP Color LaserJet CP5220 Series Printer
1) Remove Right-front cover and control-panel assembly
a) Open the front door and the right door.
b) Remove two screws (callout 1).
c) Release 3 tabs (callout 1) on the right side of the assembly.
d) While holding the assembly up, pull the cable holder (callout1)
disconnect one connector (callout 2).
2) Remove Left cover
a) Remove Tray 2 from the product.
b) Open the front door.
c) Remove three screws (callout 1). Starting from the left side
tabs (callout 2),and then remove the cover from the product.
TIP: Opening the toner-collection door might make it easier to release the tabs on the left side of the cover.
Reinstallation TIP: If the front door will not close after the left cover has been reinstalled, verify that the two tabs on the right side of the cover have been aligned correctly with the product chassis.
3) Remove Rear cover
a) Remove six screws (callout 1), and then remove the cover
from the product.
4) Remove Toner collection unit access door
a) Open the toner collection unit access door (callout 1), remove the toner collection unit, and then release the link arm (callout 2) on the left side of the door. 18798043-wfiifre4chsxw5xgazxianfb-1-48.jpg
b) Partially close the door, and then disconnect the right-hand link arm (callout 1) from the door.
CAUTION: Do not disconnect the right-hand link arm when the door is completely open. Doing so can disconnect the link arm spring. 18798043-wfiifre4chsxw5xgazxianfb-1-63.jpg
c) Rotate the access door down 90 degrees, and then pull on the left side of the door to remove the access door.
5) Remove Right-rear cover
a) Remove the rear cover. See Rear cover on page 93.
b) Open the right-door assembly.
c) Remove two screws (callout 1), release one tab (callout 2),
and then remove the cover.
CAUTION: The grounding spring on the back of the cover falls off easily. Be careful not to lose it.
6) Remove Top cover
a) Remove four screws (callout 1).
b) Open the toner-collection door.
c) Release two tabs (callout 1), and then remove the cover.
7) To Reassemble Follow Instructions in Reverse
Jul 08, 2013 | HEWLETT-PACKARD Color LaserJet CP5225...
Finding the starter on 2005 nissan pathfinder
Sep 10, 2010 | 2005 Nissan Pathfinder
Changing valve cover gasket
v6 or 4 cylinder?
SECTION 303-01A: Engine - 2.0L 1999 Cougar Workshop Manual
IN-VEHICLE REPAIR Valve Cover Removal
  1. Disconnect the oil feed sensor electrical connector.
  1. Disconnect the crankcase ventilation tube.
  1. Remove the appearance cover.
    1. Position the throttle cable out of the way, and the speed control cable (if equipped).
    1. Remove the eight bolts.
  1. Remove the spark plug wires.
  1. Detach the upper part of the engine front cover out of the way.
    1. Remove the four bolts.
    1. Position the front cover to one side.
  1. Remove the valve cover.
    1. Position the throttle cable to one side, and the speed control cable (if equipped).
    1. Remove the nine bolts.
Mar 23, 2009 | 1999 Mercury Cougar
Ibm infoprint 1332`
It's quite straight forward
1. Remove the left door.
2. Remove the right cover
3. Remove the paper support
4. Remove the redrive cap
5. Press the fuser wiper cover latch and remove the cover.
6. Remove the top cover screws
7. Remove the paper bin full sensor flag assembly from the mounting bracket
8. Remove top cover.
9. Remove 3 screws and the cables, the printhead will now come out.
10. After replacing the printhead run some test prints with the cover off, loosen the 3 screws holding the printhead to make any adjustments needed to insure the print is straight.
Jun 18, 2008 | IBM Infoprint 1332 Laser Printer
Maxi-Cosi Priori Logo
155 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
