Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Cannot scan from my canon MP140
Hello there my nae is mark, i keep getting an error code: 2,155,0 just as the scanner is preparing to scan. can you help
  • 6 more comments
  • HAZEMDENTAL Jul 12, 2008
    HELLO
    THANK FOR US
    THE CANON MP140 AT SCAN PROGRESS APPER ERROR 2155 AND NOT DO SCAN
    PLEASE HELP ME
    THANK FOR US
    BYE
  • siouxsie Jul 20, 2008
    I have exactly the same problem. Error code 2,155,0 when trying to scan. I can't print from internet either, but I can print from word. Anyone know what I should do to make it work?
  • Anonymous Aug 18, 2008
    I also get the same problem.
  • rahim_mtc Sep 08, 2008
    cannot scan from my canon MP140 problem, and notify you when a new solution is offered
  • Spoiley Sep 21, 2008
    Can someone please recommend a USB cable that they have found to solve ths problem. I've bought three and had no luck.
  • lukeisbrown Nov 27, 2008
    heloo,has anyone found a sloution yet?
    I also have this problem,really frustrating.
    Please Help,
    thank you so much
  • Anonymous Mar 06, 2009
    Salut j'ai le même probleme..
    la première fois après l'installation du pilote j'ai pas pu scanner (imprimer et photocopier, ça marche bien)... Après, ils m'ont dit change le cable il soit un peu plus court que celui que tu utilise, je l'ai changé, et et j'ai pu scanner mais juste quelque photos et après il revient le meme probleme, donc, j'ai toujours le meme probleme :(
  • Anonymous Apr 05, 2009
    dado que cuando se me termino los cartuchos , igualmente se puede escanear. Pero ahora me que dan todas la luces parpadeando y no me deja escanear , indicandome un aviso de "code: 2,114,0 en mantenimiento..Como solucionar este problema , porque aunque tuviera cartuchos con tinta igualmente deberia explorar y escanear
I had the same problem, but i just changed my USB cable to one which was thicker. Everything is working fine now
Posted on Jul 29, 2008
  • 4 Answers
Like i said in the same question in other page..... the problem could be the cable (has to be 1.20 or 1 mts) or the instalation of the printer. uninstall everything, disconnect the printer, install the driver, and then connect the printer. should work. bye!
Posted on Mar 23, 2009
I have the same problem. Need help. Thanks
Posted on Jul 06, 2008
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
How to fix error 24 for mp 160????
Hi
This is a purge unit error hence you need to check and make sure the purge unit is working fine. If not you need to clean it.
THE PURGE UNIT IS THE ONE ON THE RIGHT SIDE WHERE THE CARTREIDGE RESTS WHEN YOU TURN OFF THE PRINTER.
And at the same keep the below mentioned error list for your future use.
CANON MP140, MP145, MP150, MP160 ERROR CODES RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E3-3 = Paper jam
E4 = No ink
Direct Printing
E29 = EEPROM error
Jul 31, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Hello!
Please use the Canon MP Navigator which is bundled with your MP140. Or else you may download from http://support-my.canon-asia.com/
May 13, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
Hello!
You may enjoy the most easiest way of scanning by using Canon MP Navigator software. You may get the download from http://support-my.canon-asia.com/
Mar 22, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
E 4 keeps flashing and it wont scan for me
Coz you have not inserted with ink cartridges. Error code 4 is mean no cartridges presents.
Nov 28, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
2,789 people viewed this question
old marine
old marine
