Question about Epson Stylus Photo R300 InkJet Printer
Error message on switching on
Close cd tray - already closed
  • Epson Master
  • 691 Answers
Printer is broken. The switch on the CD is faulty.
Posted on Jul 06, 2008
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
Numark cdn450 has tray error message in left well
For all kind of brands cd or dvd players There is in every cd or dvd tray in the front bottom or under the tray so crazy you can not think an microswitch necessary that will be by mechanic close of the tray detect if the tray is closed and give a timed signal (close or open) to focus laser for reading of table of contents if the belt is bad it can take to long by a slipping tray drivebelt for the detection , or the microswitch or brass plate contacts are have a little corrosion on it or even it can be broken by a missing timing.
Dec 23, 2013 | Numark Industries Numark CDN450 Rack Mount...
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
Player will not play a loaded CD and No CD message comes up Also CD drawer opens and shuts on it`s own !!!
the tray opening by itself could be a faulty limit switch on the tray mechanism
the switch tells the system if the tray has reached the open or closed position.
if it closes then opens itself then this is the most likely
check that first
could be closing then opening without actually loading due to the switch
you will need to open it up to find the switches
usually at the bottom front were the tray goes in
darren
May 28, 2011 | NAD C542 CD Player
My CD tray closes before I insert disk
check the micro switches on the cd mechanism. these can go wrong sometimes. it's obviously not sending a message to the micro chip that the tray is open therefor it will close again automatically.
hope this helps?
May 10, 2010 | Arcam Alpha 7SE
I keep getting the close the cd/dvd guide
When you flip the main cover up, and flip the CD/DVD tray down, look at the cartridge color guide label (the colored dots). See the LIGHT CYAN dot? Directly across from that dot around underneath the gray cover is supposed to be a little plastic fin. That fin pushes the sensor switch in the CD/DVD tray to let the printer know if it is open or closed. If it breaks off, then the printer always thinks the tray is open. If it's broken off, you will have to either stick a toothpick or something into the switch, or glue a new thin piece of plastic in its place.
Mar 01, 2010 | Epson Stylus Photo R320 InkJet Printer
Recording trouble
Hi again,
I understand. Must be a glitch somewhere. Anyways, I already posted possible solutions here your original posting/problem. They were:
1. Power on the Philips FW-R7, leave the left tray empty and closed. Open the tray and put in a recorded CD (not a CDR but a regular CD from your music collection), close the right tray. Wait a couple of seconds as the FW-R7 reads the CD. Now open the tray, remove the music CD and insert your CDR. The FW-R7 should read the CDR without the error message and record to the CDR from any source. Let me know if this works for you;
2. laser cleaning or realignment (would need a service center);
3. try using lower then 40X blank CDs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 18, 2008 | Philips FW-R7 CD Shelf System
Epson stylus r300
Hi Chillyslade,
Try this..
Close the CD/DVD guide, then press the font28.gif maintenance button.
If the CD/DVD tray is inserted, remove the CD/DVD tray, then close the CD/DVD guide
Hope this works, kindly let me know by providing your valuable rating.
Thanks,
Robosoft.
Jan 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
