Question about Logitech QuickCam Communicate STX Personal Web Camera
No sound device detected or installed
I am having problems with my sound and audio device I am not getting and sound at all and computer comes up saying no sound divice installed what shall i do and which one do i install for a windowx xp home edition.
  • 1 more comment
  • mini87lham Jul 17, 2008
    no sound device is detected
  • toml77 Aug 01, 2008
    I loaded Logitech Quick Cam and lost all sound on my computer. I checked the system devices and it tells me that no audio devices are loaded. I reloaded the SB driver and bought and installed a new sound card. Nothing helps. Dell computer running W-XP.
  • Anonymous Mar 11, 2009
    i dont have sound
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Posted on Feb 04, 2009
Sound card is not detected
Sound detection requires either the audio setup within windows or the system drivers provided by the card mfg. Go to Start/Control-Panel/Devices/Sound and look to see if your hardware is there. Look at the list and if any ICON shows up indicating a device is found but not working, this could also be a problem with Drivers. Go to the maker of the card and get the current driver updates and install accordingly.
Jan 29, 2014 | IBM System x3100 M4 2582 - Xeon E3-1220...
Detected a problem with sound device keeps coming up
Please correct sound driver install. If you are correct install then go to control panel and sound and audio device click and check all points. If all thing ok then one time windows format may be solved your problem. Because some file miss but not error show that time format windows and solved all problem. If not format windows then you are check sound to another computer, you identify what a problem.
Thanks..
Oct 27, 2013 | Dell A215 Computer Speakers
Asus p5q se plus no sound
Hi sir/madam
First uninstall audio drivers which u installed.
Then download the drivers
Try this link from original site
https://www.asus.com/Motherboards/P5Q/HelpDesk_Download/
There download only audio drivers and install it..
If still not works , reply me
Sep 21, 2017 | ASUS P5Q SE PLUS Motherboard
My computer is not detecting the new speakers that i just plugged into it
install the audio card driver ,,, the problem is not with your speakers it is with the audio card ,,, you must install the driver,,
Mar 14, 2012 | Sony Audio Players & Recorders
No audio device in my computer, how can i check if my sound card have defect?
If the computer prompt you that you have no audio device, then your soundcard really is defective or has a dirty contact point of which your computer cannot detect. Clean the contact points first, then plug it again on your computers internal PCI slot that is located on your motherboards surface. If your computer still cannot detect a new device installed, then your sound card is definitely defective and needs to be replaced. But if your computer has detected a new hardware device installed but prompt you to install a driver, then your sound card is working properly and just need the proper driver for it to work properly. Just install the sound card driver from the mini disk that you have. When you buy a sound card a mini disk always goes along with it. Hope this would help you. Have a nice day my friend.
Aug 17, 2011 | Computers & Internet
SoundBlaster Live 24-Bit PCI Sound Card Installation
Kindly remove the sound card out from your motherboard. Power on your computer and then go to BIOS settings. Look there for a settings relating to Audio device and then turn it off . The audio device in your motherboard will now be disable. Plug in back your soundblaster sound card, power on your computer and then install the driver for it.
Dec 17, 2009 | ASUS M2N68-AM SE2 Motherboard
"no audio device installed"
First check the device manager from the control panel. Check and see if there is a audio device detected and if it is a problem device.If the device has a problem try removing the audio software and then remove the audio device.then re-boot the computer and windows should detect the hardware and begin installing drivers. Make sure you have the updated drivers from Dell downloaded and the updated software. If it does not detect the hardware after re-boot you can try adding hardware manually in the control panel and have it auto detect any new hardware. If these thins do not work the audio card or built in audio may have stopped working. You can buy a basic PCI audio car for fairly cheap to install on your computer if you cannot get the audio to work.
Sep 05, 2009 | Dell Computers & Internet
We have no sound coming from our PC. There are
To check, click windows start button, point to computer, click manage, then look for device manager. If you see an exclamation or "x" mark on your audio device this means that your audio driver is not properly installed.
If audio no error marked sign and says that your audio driver is ok, uninstall it then re-install the audio driver.
Jun 04, 2009 | HP (153147-001) Sound Card
Audio is not working for P5SD2-VM motherboard...
You probably need Microsoft UAA drivers first
1) Remove any installed audio drivers through device manager
2) Download Microsoft UAA drivers for your O/S
3) Install them and reboot
4) go to device manager right click sound and update driver
It will go on the net and in most cases find and install them
Nov 28, 2008 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
My computer cannot detect multimedia audio controller
Download Microsoft UAA driver then install it
Uninstall any sound driver first then
Go to device drivers and update your sound driver will go on net and find them and install them
Nov 01, 2008 | ASUS P5S800-VM Motherboard
Logitech QuickCam Communicate STX Personal Web Camera Logo
101 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
