Question about Belkin (F5D7230-4) Router (587009)
Fading Signal after a year of usual usage ,I noticed that it is no longer that efficient as before
    Scholar:
  • 77 Answers
Several factors can affect the overall signal strength. One is that there might be more interference in the area using the same frequency. i.e cordless phones. Cordless phones transmit on a frequency of 2.4 mhz...oddly enough that is the same frequency that most routers transmit on. One way you might be able to aleviate some of the interference is to go into the router settings and manually change the channel. Just make sure that you go into your wireless adapters settings at each of your wireless computers and have them changed to the new channel as well.
Hopefully this clears some of the issues up for you.
Good Luck
Posted on Jun 30, 2008
How do you know if a watch battery is fading. On some watches the second finger moves two seconds at a time but on one of my watches it is just losing time.
If it looses time and it has been like more than 2 or 3 yrs since replacing the battery it could be that the battery is loosing power. loosing time is a symptom of a fading battery power.
Mar 10, 2015 | Nixon Watches
Philips 8300 steam generator iron keeps cutting out
I have this iron about 2,5 years, work a few times. when i shut down the steam generator the iron stays on. And now in one hour of work it shuts downs about 4 times. the lights on the steam generator are week. what main board i shuld switch?
Mar 21, 2013 | Irons
SERVICE ENGINE SOON LIGHT CAME ON READS CODE P0431 AND P0421
Converter is not working as efficiently in Bank 1 and Bank 2 (two codes)...
P0421 - Warm Up Catalyst Efficiency Below Threshold (Bank 1)
Basically this means that the oxygen sensor downstream of the catalytic converter on bank 1 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
Symptoms: You will likely not notice any drivability problems, although there may be symptoms. The code may be more likely to occur after the engine has had numerous cold starts in the past 1-2 days.
Causes: A code P0421 may mean that one or more of the following has happened:
The catalytic converter is no longer functioning properly
An oxygen sensor is not reading (functioning) properly
A sparkplug is fouled up
Possible Solutions:
Measure the voltage at the oxygen sensor on Bank 1 (the rear sensor, or the sensor after the converter). In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
One thing to note is that many vehicle manufacturers offer a longer warranty on emissions-related parts. So if you have a newer car but it's out of it's bumper-to-bumper warranty, there still may be warranty on this type of problem. Many manufacturers give a five year, unlimited mileage warranty on these items. It's worth checking into.
P0431 - Warm Up Catalyst Efficiency Below Threshold (Bank 2)
Basically this means that the oxygen sensor downstream of the catalytic converter on bank 2 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
Symptoms: You will likely not notice any drivability problems, although there may be symptoms such as a rough/hard idle when cold.
Causes: A code P0431 may mean that one or more of the following has happened:
There is an exhaust leak
Possible Solutions:
Inspect for exhaust leaks. Next step is to measure the voltage at the oxygen sensor on Bank 2. In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
Hope this helps.
May 05, 2011 | 2004 Mitsubishi Endeavor
Interior of Jenn Air side by side frig has odor or burned rubber inside. frig is 10 yrs old and has also had problems with ice build up on coils and I have had to manually defrost when it no longer cools....
would like to say yes but parts for this unit are scarce and expensive,10 years is pretty good and if you do decide to change it you will notice a big difference in running costs/efficiency.
Oct 22, 2010 | Jenn-Air Refrigerators
I have an Advent 7204 laptop two years old and suddenly it doesnt work anymore. When turning on, the lights which flash on went all the way through as normal then suddenly started fading and the machine...
I would suggest you to check with a different adapter, first.
You don't have to buy a new adapter for that.
Try to borrow from someone who has a compatible adapter.
Mar 13, 2017 | Dell Latitude D600 Notebook
I replaced my water pump at 90,000 miles. Do I have to replace it again at 180,000? I have 182,000 on my 1998 Honda Accord EX, 5 Speed. Also how long do the clutches last? Also the paint does start fading...
firstly replacement waterpump is not time sensitive,change it when it goes.
the clutch can last from 7seconds,foot rest, to 150k if driven long distances,sometimes longer,
the paint is water based and should be waxed every year to stop it fading too badly,(good maintenance always pays off.....)red/blue are the worse.
May 04, 2010 | 1998 Honda Accord
Signal Fading In and out
Most of the Xact models use the standard Sirius antenna. Unfortunately Xact no longer supports satellite radios. You can get a replacement antenna from any Sirius dealer and see if that works. Sounds like the antenna wiring might be broken or shorted out.
Dec 25, 2008 | Sirius Satellite Radio Receiver
7 year old sony wega 32 inch
There are 3 components that control color, and it sounds like one of those are bad.
You will have to get it repaired.
I would talk to your local repair shop, and see what their estimate is, before deciding on repair or replacement.
Mar 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Old Polaroid photos
Having photographic quality copy prints made will give you far longer life than the original Polaroid. Polaroid colour dyes will shift colours and eventually fade dramatically. New photographic (and some ink jet) prints will last generations without noticeable fading.
Feb 24, 2008 | Photography
Fading Signal Strength
could be a worn rf modulator
this controls the radio frequencies.
If you are having trouble with dropping calls that last for a little longer than normal 1-2 mins then that would be my guess
Nov 08, 2007 | Nokia 3120 Cellular Phone
Belkin (F5D7230-4) Router (587009) Logo
43 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
