Question about Panasonic DMR-E30 DVD Recorder
Panasonic DMR-E30 with U99 fault
Every time I turn the recorder on it displays U99 and does not oprate at all,
  • 1 more comment
  • Anonymous Sep 20, 2008
    My unit displays U99 only too. When I turn it on, it displays the timer, but it doesn't operate anything else. What should i do?
  • zackberry Nov 16, 2008
    My DVD-RAM disc I've been using displays the U99 error code when I put it in. It then will not eject and all functions are disabled. I have to turn the unit off then on and hit the open button at just the right time or it's stuck again. Any solutions?
  • hemorel Nov 19, 2008
    Same problem. It happens when I placed my DVD RAM. There is no problem by playing films on DVD or music on CD's
Saludos : Yo tenia el mismo problema. Mi dvd DMR-E30 tenia el
mismo problema . Codigo U99 . Y no funsionaba nada.
Entre a la pagina de soportes de Panasonic y baje el Firmware.
Luego lo grabe en un cd ,el cd lo coloque en la dvd y la dvd se actualiso automaticamente. La dvd funciona perfectamente tanto
con DVD-RAM como con DVD-R. Esta solucion la saque de esta
misma pagina fixya . Gracias Fixya. Att. LACF
Posted on Jan 01, 2009
Display reads slf check and u99 whichIthink is a fault code.The unit is apanasonic DMR-ES30VEB dvd recorder/vhs.Any ideas?
Hi
U99 is a fault code, from memory i believe it is a communication error between the dvd drive and its controller, either way the machine needs to be serviced.
regards
TechSupp12
Dec 12, 2010 | Panasonic DMRES30V DVD Recorder/VCR Combo
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
U99 n cant get to work
? The unit fails to operate properly. -Press [(!), DVD POWER] to switch the unit to standby. Now press [(!), DVD POWER] again to turn the unit on.
Sep 15, 2009 | Panasonic DMR-E30 DVD Recorder
Panasonic Video/dvd player DMR ES30v Fault code U99
Hi,press the power button on the dvd so it goes to standby,then press the power button again to turn the unit on.I hope this helps.Jamie
Mar 12, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-EX85 fault code U99
This is the solution from the on line owners manual for you product at www. panasonic.com. U99 ≥The unit fails to operate properly. Press [POWER í/I] on the main unit to switch the unit to
standby. Now press [POWER í/I] on the main unit again to turn the unit on. I hope this helps you with your problem.
Jan 30, 2009 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
U99
A U99 error code signifies a general communications failure and is not associated with any specific problem. It could even be related to the firmware version of your DVD recorder.
Try turning off the power and unplugging off-unplug for at least five minutes before reconnecting.
If U99 reoccurs, you should contact the Global Service Center Network for assistance.
Jan 27, 2009 | Panasonic DMR-ES10 DVD Recorder
Dvd would not work displays u99
Dvd recorder doesn't not work. Displays error code U99. Any suggestion please?
Jun 21, 2008 | Panasonic DMR-E85H DVD Recorder
Start up u99 message
Hi there, this is what Panasonic say.... The "U99" error code signifies a "general communications failure."
Feb 17, 2008 | Panasonic DMR-E20 DVD Recorder
U99
Feb 12, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-E30 DVD Recorder Logo
1,059 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
