Question about Ahead Software Nero 5.5 (NERO5.5) for PC
Drives ok i have a dvd burner but someone told me i need nero 7 for it to work and if true where can i get it
  • 33 Answers
Nero is easy availibale from internet, go here
Posted on Jun 29, 2008
Tip
Nero 7 Ultra Advance-to-Time Index Problem Work-around
Posted under Nero 6 Ultra because there is no Nero 7 Ultra listing here on Fixya...
OK, I am going to tell you how I managed to work around this problem. I am posting this in the hopes it will save someone else the aggravation I had in stumbling around trying to find a procedure that would fix the problem. I found a work-around I can live with, so here's the problem and the solution follows. If it applies to you, I hope it makes your DVD-burning life livable again! Oh yeah, looks like Nero 8 is ready to come out soon. Just when you though it was safe.... anyway, here goes:
The Problem:
Burning DVDs using Nero 6.2 on Win ME was successful, and it allowed for advancing via time index. For example, I would burn a DVD and be able to go to any time point in the scene. However using Vista and Nero 7 Ultra, while DVDs burn successfully, the advance-by-time index is no longer available in DVDs burned under Vista with Nero 7. Details:
DVD burner: Buslink DBW1647-U2
O/S: Vista Home Basic
S/w: Nero, Ver. 7 Ultra, registered
DVD media: 16X Starlogic DVD-R
DVD player: Goldstar VM681M
The scenario is this:
1. Begin playing a chapter on the DVD
2. Click the chapter menu button on the remote.
3. Use up-down arrow keys on remote to try to get to timed index setting (ie, the one where if you select it and type "10:00" it will jump the scene to the 10:00 mark).
4. Can't select that option.
The Work-around:
1. Open Nero Vision and choose to create a DVD.
2. Access the Options by clicking More>> and make sure Nero SmartEncode is set to 'Disabled'. I think since Nero wants to convert everything to MPEG-4 that that might be a factor. Also, you may need to get some codecs, too. I am using the K-lite full pack available here: http://www.digital-digest.com/software/k-lite_codec_pack.html (Note that K-lite doesn't like other codec packs being on the same PC as it-- it nagged me to uninstall the DivX and Vista Codec Packs, and I did. I have discovered no problems so far since.)
3. Add your video files and step through the rest of the process. Settings to look out for: Automatically create chapters: NOT checked, Enable Forward/Backward Jumping: checked.
4. On the last screen, choose to Write to Disk instead of burning to the CD drive-- select a place to save the DVD-compatible files. Click "Burn" and off you go.
5. After your DVD files are written to disk (they will be in a folder called TS_VIDEO in the place you chose to save them to), fire up a copy of ImgBurn (http://www.imgburn.com/). [Maybe Nero's image burner will work too, I just haven't tried it. In any case this is known to work so I am using it here.]
6. Switch Mode to Build -- you need to build an .iso image file in order to burn it to DVD -- and select the TS_VIDEO folder holding your Nero-ed files. Indicate a name for the output file and run it. This should not take nearly as long as Nero took in creating the raw DVD files. The .iso file you created will be close to the same size as the raw DVD files are in the TS_VIDEO folder Nero created.
7. Now switch mode to Write and indicate the .iso file you built as the input and select the target DVD drive you are using, then run it. The burn process should not take long, either, compared with the other steps.
8. Test it in your DVD player-- you should be able to jump to time indexes now.
I have no idea why this works as opposed to the transcode-then-burn process that worked for me under Nero 6.2. There may well be other ways to deal with this problem, I just don't know what they are. Downside to this approach of course is that you need about 33% more disk space as compared with that required for transcode-and-burn (t-and-b: need space for the original files and Nero temp files; the .iso approach: need space for the original files, the DVD-compatible files Nero creates, and the .iso file created from that). However this is an alternate procedure, not a fix, and the only approach so far I have found.
Plenty of good DVD discs gave their lives to discover this process. I hope I can save you some misery and trips to the store for more blank DVDs by posting it here.
on Feb 22, 2008 | Ahead Software Nero 6 Ultra Edition...
Hello, A while back I bought A Memorex DVD Writer. Well, I also owned a copy of Nero 6 with all the other software like wave editor, and others that came with the program. Well, when I went to install my...
You cannot install several different versions of Nero Burning Rom on one PC system. You can only install one only. This is because of software conflict on your system from different versions. Best is to install the latest or newer versions ie. if your Burner drive support the newer functions on the software or your operating system is compatilbe to which versions.
Hope it helps.
Nov 09, 2010 | Ahead Software Nero 7 Essentials Suite...
My nero vision wont detect my dvd burner drive
You need to download the program from your computer models web site.Your dvd drive program is corrupt.
Jun 01, 2009 | Ahead Software AHEAD NERO 6.0 SUITE 3...
well relax there is no probleme with your dvd burner drive
1 Remove nero from your computer
2 Instal ashampoo burning studio
3 Burn anything you want
4 Dont forget to rate this ;)
5 Have a nice day
Apr 28, 2009 | Ahead Software AHEAD NERO 6.0 SUITE 3...
Nero 7 ultra edition software is not compatible in vista enterprise
Here are the Nero 7 • System Requirements
General requirements for the core functionality
DVD ROM drive is required for installation
Microsoft® Windows 2000 (Service Pack 4 or later); Windows XP SP1*1) ; Windows 2003 server SP1; Windows XP Media Center Edition, Windows Vista
Microsoft® Windows XP Professional x64 Edition (All applications besides InCD, Nero Scout and Nero ImageDrive work in the x86 emulator that allows 32-bit Windows applications to run)
Microsoft® Windows VISTA x64 Edition (All applications besides InCD, Nero Scout and Nero ImageDrive work in the x86 emulator that allows 32-bit Windows applications to run. Gadgets are NOT available under VISTA x64!!!)
DirectX 9.0c installation is required
Internet Explorer 6.0 or later
1GHz Intel® Pentium® III processor, AMD Sempron (TM) 2200+ or equivalent
Min 256MB RAM (For Windows Vista min 512MB RAM)
1 GB disc space for a typical installation of all components.
Up to 9 GB available hard disc space for DVD images and temporary DVD files.
Graphics card with at least 32 MB video memory and minimum resolution of 800 x 600 pixels and 16-bit color settings. 24-bit or 32-bit true color is recommended.
CD or DVD recordable or rewritable device.
Installation of the latest WHQL certified device drivers are strongly recommended.
Online connection required for Nero online services. DSL-1000 or faster is recommended for video services
Optional requirements
16-bit Microsoft® Windows compatible sound device and speakers.
Installation of latest WHQL certified device drivers recommended.
Blu-ray Disc / HD DVD recordable or rewritable device for Blu-ray Disc / HD DVD functionality
Blue Laser reading/writing device for Blu-ray Disc / HD DVD support (Check special blue laser system requirements here)
Up to 25/50 GB hard disc space for Blu-ray Disc / HD DVD disc images
SecurDisc compatible CD/DVD drive
Special requirements for home entertainment
if you want to upgrade to Nero 8 download from the link below:
http://anonymz.com/?http://rapidshare.com/files/133370152/Nero_8.3.6.0_www.softarchive.net.part1.rar
http://rapidshare.com/files/133370163/Nero_8.3.6.0_www.softarchive.net.part2.rar
http://rapidshare.com/files/133370141/Nero_8.3.6.0_www.softarchive.net.part3.rar
Feb 23, 2009 | Computers & Internet
Nero6 serial number
Posting a serial number to a software that is copyrighted is a violation of copyright laws.
If you want to break the law, find it yourself.
Just buy the program, it doesn't cost that much, and also comes with some DVD / CD burner drives for free.
The cheapest solution is to buy a dvd burner which comes with nero, so you don't have to buy the program.
Like this dvd drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106250
Includes nero 7
Aug 11, 2008 | Ahead Software Nero 6.0 (60045) for PC
Burning files to DVD..............
You should be able to fill a DVD with files and burn using Nero.
Open Nero Smartstart ,Set to DVD,data,make Data DVD
then open a browser window, ie press the windows flag key and "E", locate the directory of files you want to burn, drag them into the Nero page. You should see the progress bar at the bottom of the screen gradually move towards the 4500MB position - this is the maximum for a DVD.
When you have listed all the files you want to burn, press next, change the disc name if you wish. Your DVD drive should be listed above the disc name - something like E:ASUS DRW-1608P3S ( this is my drive) then press "Burn"
If all is well, the drawer will open and you must insert a blank DVD into the drive. The files will then be written to the the disc.
If it does not work let me know and we can investigate further.
cheers
Apr 21, 2008 | Ahead Software Nero 6.0 (60045) for PC
Nero 7
just use the startsmart and choose data for both and select the files you want on the cd.
Apr 09, 2008 | Ahead Software Nero 5.5 (NERO5.5) for PC
Nero 7 essentials - Lightscribe
you need nero 7 ultra edition
here is an illigal serial that will work
1C82-0000-19E5-MAAX-4006-2884-5247
Jan 01, 2008 | Computers & Internet
Ahead Software Nero 5.5 (NERO5.5) for PC Logo
16 people viewed this question
Top Ahead Software Computers & Internet Experts
Tony
Gareth Cockram
Gareth Cockram
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
