Question about Sony NetMD Walkman MZ-NF810 Player/Recorder
Battery will not charge
Purchased a new battery, works with charger plugged in, but the battery will not charge and it shows no sign of it trying to. Will not work with new battery because it needs to be charged. Anyone know of a good repair place or does someone want to buy mine for cheap? Peace and Audio! Brian
  • 31 Answers
Hey call the people and they should replace it for free.
Posted on Jul 06, 2009
Phone shows its name while plugged in and repeat the same process over and over but does not charge
Sounds like the battery has corroded or gone bad. TRy Zbattery.com for extremely low price.
Jan 17, 2015 | Cell Phones
Samsung 3262 charging paused for battery
Since you are experiencing difficulty in your charger since your Samsung 3262 won't charge although it is showing it is charging battery then we will be solving this matter so to fix battery and charger problem. • Performing a power reset. •Hold the power button for 30 seconds without it being plugged in. •Then place your Tab on a home charger for a couple minutes. •After a couple minutes, press the power button again for 30 seconds with the charger plugged in. This is usually a charger issue But in a small amount of cases it can be the battery. If recently purchased you can just return it and get a new phone.
Sep 29, 2014 | Cell Phones
Mini 1012. new battery. charger led working, battery wont charge. when plugged in charger works for about 30 seconds
Seems like you may have purchased the incorrect battery or they shipped you one that is NOT for your unit, if you purchased an "aftermarket" battery this could be the issue. Not saying aftermarket parts are bad, they are just massed produced and sometimes you get a bad one. Return it for refund or replacement. Try E-Bay for a reseller for this product, much less cost.
Jan 28, 2013 | Dell Inspiron Mini 1012 Netbook...
Battery charging but laptop won't work while plugged in
The purchased is sub standard. Get a replacement from the store. N.B the fujitsu charger will work for some
Time and damage your laptop because of the higher amp
Jan 27, 2013 | Toshiba Satellite Computers & Internet
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
When my acer aspire 5734z laptop is plugged in the charger indicator flashes and the battery indicator shows blue.it stays at 0% and says plugged in,not charging.if i unplug the charger it shuts down. need...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 11, 2011 | Computers & Internet
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Feb 15, 2010 | Olympus Evolt E-510 Digital Camera
I put my camcorder to charge, but it won't charge at all
If this is happening with your new battery, your charger is possibly defective and improperly charging. I suggest trying a new charger!! Hopefully this helps,,please rate thanks!!
Aug 05, 2009 | Video Cameras
Sony NetMD Walkman MZ-NF810 Player/Recorder Logo
196 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
