Black & Decker D2030 Iron Logo
Posted on Dec 09, 2010
Water shoots out when trying to steam. - Black & Decker D2030 Iron
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Dec 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
14707
Points
34
You are getting a lime (scale) build-up in the iron. Best to try a clean, either with a self-clean function, or buying a lime remover solution for kettles and irons.
I cannot get my GCSBDS212 steam iron to make steam.
Have a look at the steam holes in the bottom, they should be nice an clean with no blockage. If they are blocked up you will need to remove the calcium buildup inside the iron. Get some LimeAway at HDepot, pour it into the water reservoir, let sit overnight. Next day turn the iron on and try steaming on some old papers covered with an old rag or towel, once it starts working steam for a few minutes, then unplug, drain it, put in clean distilled water and flush it out until the steam comes out clear. Use distilled water not tap water, it has much less mineral content and will be less likely to plug it up. Most pharmacies and Walmart sell distilled water. ! gallon about $1.25.
1helpful
How to flush brown fluid water from Sunbeam Steam Master
Run a tank of 50/50 water and white vinegar through the steam cycly. Run two or three more tanks of plain water. This should clean it out safely.
5helpful
2answers
SAND LIKE SUBSTANCE COMING OUT OF IRON
Yes, there is a "Solution" you could use in the reservoir to remove the crud. First of all, STOP using tap water. What you have is mineral deposits inside your iron from using tap water. Use ONLY steam distilled water. I usually find this at my grocery store.
To clean out your iron, use white vinegar in your iron instead of water. This is to CLEAN the iron ONLY! Do NOT use to press cloths! And make sure the steam and/or water flow very clear (free from "sand", dirty water/steam or any other contaminates BEFORE using iron to press your cloths. You may need to flush the iron with water (remember, steam distilled ONLY) more than once to get all of the vinegar out.
Hope this helps...
1helpful
How to flush brown fluid from Sunbeam Steam Master steam jets and increase steam shooting?
There is commercial iron cleaner, but you can use white vinegar and distilled water to flush it. I would use a mixture of half and half. Then let it steam its little self, when it is clear, rinse with the distilled water again, This kind of thing happens when you use tap water and let it sit in it without rinsing after using. I always use distilled water and empty right away after use. Good luck
I love my iron, BUT I used to be able to clean it by the recommended method, but now it will not shoot out steam to clean the holes. It does not steam on clothes even though I prees the steam button. ...
Put in as much white vinegar as possible and then turn iron on. Let it stay on for about 30 minutes the try the steam button. Once the steam button begins to work empty the vingar an fill with distilled water to rinse. You'll need to rinse several times to get all of the vinegar out.
Leaks water out all the time. Clothes wet or rust marked.
OMG, how frustrating to be ironing and water shoot out everywhere from this iron....So, to remedy it, I have turned off the steam, use it as a dry iron, and have a spray bottle handy to spray as I iron...love the feel of this iron, but hate the water everywhere...
1helpful
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Water shooting out bottom holes
This normally means that the iron is not heating up enough check that you have adjusted the temp so it is not as the water will either come out of the bottom when not hot enough to steam or when the jets get dirty and need cleaning.
Thanks J
Top Black & Decker Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
