Question about Patton Electric U2-20 Box Fan
WHILE CLEANING IT THE LIGHT GREEN WIRE CAME DISCONNECTED AND I DONT KNOW WHERE IT HOOKS UP
WHERE does the light green wire connect to?
  • 5,568 Answers
If it is coming from the power cord, it is certainly a safety ground wire and is attached to the round pin of the AC cord.
It can be attached anywhere to the metal frame of the fan.
Its purpose is to drain off any leakage current from the motor or other part carrying line voltage to avoid having dangerous voltage occurring on parts you can touch.
If your house is equipped with Ground Fault Interrupters (GFI), this ground is a little less important since the GFI monitors the current in the high and low sides of the AC line and if there is any difference between incoming and outgoing currents, it will trip to protect against shock.
Posted on Aug 06, 2008
What are the color code of the wires to switch terminals
Almost!
the black screw is the "common" so the hot wire or the colored wire (usually black or red) bringing power in goes on to the black screw and all white wires (neutral) get connected together. you need to verify which wire has constant power when all wires are disconnected and separated first.
*White wires all connected together separate of the switch
green screw = ground or bare wire
black screw = hot wire/ wire with constant power
silver screws = (switched terminals) black or colored wire from each device being powered (eg. light) per screw
Dec 22, 2012 | Leviton 003-1755-W Three Rocker Switches
How do i remove the sensor for the rear tailgate?
1) Locate and remove sensor.
The sensor is located under the drivers tail light. Unclip it from the body and then unplug it.
2) Bypass the tail light circuit.
Connect the tail light signal wire (Green) to the tail light wire (Green w/ Red Stripe). I recommend using wire tap in squeeze connectors that way you dont have to cut any wires.
3) Bypass the brake light circuit.
Connect the brakelight signal wire (Green w/ White Stripe) to the brake light wire (Red w/ Blue stripe) and the the 3rd brake light wire (Red w/ White Stripe). Again all three of these wires are to be connected together.
4) Throw away your broken Tail Lamp Failure Sensor
Do not plug your sensor back in. Doing so will cause the annoying orange lamp failure warning light on your dash to stay on. Leave it unplugged ant the light will stay off.
5) Test your work
Turn on your lights and make sure your tail lights work properly. Have a friend step on the brake pedal, and make sure your brake lights work properly as well. Dont forget to check the Third brake light.
Sep 20, 2012 | 2002 Chrysler Voyager
I removed an outdoor light fixture on my garage to replace with a new one. It has a plastic box mounted in the brick .I disconnected the white and black wires and noticed the ground wire just lying in...
If your old light was all plastic, as I suspect it was, there was nothing to ground. Your new light evidently is all or part metal. Fasten all the green/copper wires together and make sure the metal bar inside, if one, is also connected. Use a wire nut to make the connections. My preference is to attach a separate wire to the metal mount bar and then fasten all three ground wires together using the wire nut.
I hope this helps you ... Thank you for your interest in FixYa.com
Jul 10, 2011 | Microwave Ovens
How to wire
This should replace any existing single pole (one location) switch. You have two wires on the pir, black and blue and then the ground. The black hooks to the hot or common wire. It may be black, but it will be the hot wire. The blue wire hooks to the wire going to the light. The ground hooks to the green or bare.
Mar 05, 2011 | Leviton Decora Wall Switch With Pir...
Yes im tring to find the parking wire i dont know what color it is trying to watch video not working
The parking brake wire for this unit is light green. Try connecting it the unit's ground wire (black) and test for video. If it does not show video when connected to ground, install a two wire toggle switch. Connect one wire of the toggle switch to the light green wire and and the other wire of the toggle switch to ground. In this manner you will be able switch the screen on and off when viewing videos.
Nov 23, 2010 | Kenwood DDX514 Car DVD Player
I need to know the stereo wiring for a 1998 ford windstar. im trying to put in a new and i dont know what wires to match it up with
here you go...
1998 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 16, 2010 | 1998 Ford Windstar
1996 Camry Tail ights not working
So its a wagon? or I dont know what S/W is. If the license plate light works, the light failure sensor could be bad. It should be in the left rear corner area and have 4 wires. Green, Light Green, Yelow/Green and White/black. You should have power on the Green going into the box, and the Light Green out to the tail lights. If you have power on the Green, but no power on the Light Green, then the box is bad, either replace the box, or you can just connect the Green to the Light Green wire to get tail lights operating.
May 12, 2010 | 1996 Toyota Camry
Hampton bay ceiling fan
Your black wire hooks up to your fan. The blue wire hooks up to your light. And your white wires hook up with the white wires from the fixture, and the bare copper wire hooks up to your green ground wire. Please contact me if you need further help. Good Luck, and I hope this works for you. Jim
Apr 07, 2010 | Hampton Bay 24002 Ceiling Fan
I am installing a sony cxs-gt09hp in a 2003 f250 and the wires dont match need to know what wires hook together
You should really invest in a $15 wire harness so you do not have to cut the factory plug.
Instructions will be in the package - but in the event you dont have a factory plug due to theft - here is the vehicle's wiring color codes...
Car Radio Battery Constant 12v+ Wire: Light Green/Pink
Car Radio Accessory Switched 12v+ Wire: Black/Violet
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Antenna Trigger: Blue
Left Front Speaker Positive Wire (+): Light Blue/White
Left Front Speaker Negative Wire (-): Orange/Light Green
Right Front Speaker Positive Wire (+): Dark Green
Right Front Speaker Negative Wire (-): White/Light Green
Left Rear Speaker Positive Wire (+): Tan/Yellow
Left Rear Speaker Negative Wire (-): Gray/Light Blue
Right Rear Speaker Positive Wire (+): Brown/Pink
Right Rear Speaker Negative Wire (-): Orange/Red
Thanks for using FixYa!!
Dec 28, 2009 | Car Audio & Video
Digital clock
Here is a wiring diagram of the radio by wire color:
Radio Constant 12V+ Wire: Green/Yellow
Radio Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Green
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Blue
Radio Amp Trigger Wire: Blue (Same as Antenna Trigger)
Front Speakers Size and Location: 5′ x 7′ Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers SIze and Location: 5′ x 7′ Rear Deck
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Aug 14, 2008 | 1988 Ford Mustang
Patton Electric U2-20 Box Fan Logo
95 people viewed this question
Top Patton Electric Dryers Experts
Darrell
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Patton Electric Dryer Expert? Answer questions, earn points and help others
