Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
Baby Gaggia White Color
Hello, I own a Baby Gaggia with a coffee grinder. My problem is that I cannot get it to even turn on after I plug it in and try to turn the knob from zero to one. I am not sure if this device has a fuse that may need to be replaced or not.
If it is a fuse problem, can you please provide the part number that I would need and where to purchase it? Thank you in advance.
Below is the link to a picture of the model of Baby Gaggia that I own:
http://www.espressotec.com/store/pc/catalog/pdf1/ga1110_gaggia_old_baby_manual.pdf
  • Anonymous Mar 29, 2014
    Fuse in plug uk
  • 515 Answers
If you take of the top then you can see the boiler, on the top of the boiler you will see thermostat in the middle on one you will see a little pin, press down the pin to reset.
Posted on Jul 12, 2008
Netherlands
Hi There,
That sounds like your coffee grind or tamping needs to be adjusted or the shower screen may need cleaning.
Pressurised water looks for the weakest point when extracting and if grind is too coarse or tamp is off, it will come out one side mainly.
If you don't have a grinder add extra coffee in the portafilter basket.
If is still spurts with the portafilter off - the shower screen may need cleaning - take it off and soak in coffee cleaning solution. Puly Caff coffee cleaner
Oct 21, 2017 | Gaggia Coffee Makers & Espresso Machines
Does the gaggia titanium have a grinder sensor? Can anybody tell me where it is? I have the "grinder blocked" message. I've cleaned the grinder, Shute and doser door, but I still have the...
Hi...Grinder blocked message is ..when you make coffee there is no current going into the grinder. In other words the grinder motor is blown(coil windings in the motor is blown). You have to replace the motor. The problem is common with Gaggia, Talea, Odea coffee machines. hope your machine is less than 2 years old to get fix under warranty.
Apr 10, 2012 | Gaggia Titanium Espresso Machine
Need operating & maintenance manual for brevetti gaggia mdf burr grinder.
Hello, your instruction manual can be found on this link by clicking or copy and pasteing it to your browser http://www.gaggia.com/dam/bo/allegati/files/31_mdf.pdf if you are unable to obtain these instructions by copy and pasteing to your browser please message me back and I will provide my email so that I may send you them directly.
Thank you
Rick
Nov 08, 2011 | Gaggia MDF Electric Burr Grinder
My baby gaggia is putting out water too fast resulting in weak coffee.
Adjust the coffee grinder to finer. (coffee grounds are too coarse)
Jan 17, 2011 | Gaggia Baby Espresso Machine
I have a Gaggia syncrony compact coffee machine and the coffee grinder has jammed for the second time. The repair agent employed by Gaggia inform me that they have been waiting for spare parts from Gaggia...
If the grinder jammed it might have been because the grind was too fine, try adjusting coarser then using the + or - lever to add more coffee for proper extraction. To clear jam remove brew unit and locate door to grinder chamber on left, vac out grounds, also beans in hopper. When clean run grinder and set to coarser, then add small amount of beans and test.
Aug 25, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia platinum vision grinder not working
The grinder is faulty,take the unit to a service agent for repair
Dec 29, 2009 | Gaggia Platinum Swing 2-Cup Coffee Maker
How can I clean my Gaggia burr coffee grinder?
For parts you can see, use an artists paintbrush. If you want to clean the internals, grind some panko breadcrumbs or raw rice grains, then run some coffee through it a few times before using.
Dec 10, 2009 | Gaggia MDF Electric Burr Grinder
Gaggia coffee
Do you prime the machine when you connect it to power?
Feb 01, 2008 | Gaggia Coffee In White, White MDF...
Re setting
There is no way to do this. One controls flow by the pressure of the tamp, and fineness of the grind. 2.25 ounces or espresso in 20 seconds from 14 grams of coffee.
Dec 02, 2007 | Gaggia Coffee In White, White MDF...
Broken Handle on Coffee Grinder
Nice unit! Replace the part. Try www.smallappliance.com.
If you want to try to glue it first, get a product from 3 M. I think they call it super strength glue. Scrape off all traces of whatever you used before. Follow the instructions exactly.
Nov 24, 2007 | Gaggia MDF Coffee Grinder
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
96 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
