Traulsen AHT232D-HHS Stainless Steel Commercial Refrigerator Logo
Posted on Dec 09, 2010
Best way to install new door seals. - Traulsen AHT232D-HHS Stainless Steel Commercial Refrigerator
CoolerGaskets
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Jan 02, 2014
CoolerGaskets
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
6861
Points
31
Doug,
Watch our How to Videos here: http://www.coolergaskets.com/how-to-videos/
Replacing your gaskets are a pretty simple process. Have you already found your replacement gaskets? If not we'd be happy to help! What we need is your Traulsen Model and Serial # and we can locate the gasket needed for your unit. All of our replacement gaskets come with a simple installation instruction worksheet.
Visit us here: http://www.coolergaskets.com/
or email us with your information and we'll be happy to help - [email protected]
Matt
Toll Free # 855-288-2259
How to replace the bottom door seal on a Electrolux Dishlex dishwasher DX303WK
How to replace the bottom door seal on an Electrolux Dishlex dishwasher DX303WK.
To Note: Before you begin, make sure you have the correct door seal for your dishwasher model. Before beginning any repairs, switch off the dishwasher and unhook it from the power source.
Materials Needed:
  • New door seal compatible with Electrolux Dishlex DX303WK
  • Screwdriver
  • Pliers
  • Clean cloth
Step 1: Remove the Old Door Seal
  • Open the dishwasher door and locate the existing door seal around the bottom edge of the tub.
  • Gently peel back the old door seal from the edge of the tub. It should be secured with a rubber gasket or clips.
  • Use a screwdriver or pliers, if necessary, to remove any retaining clips or fasteners holding the old seal in place.
Step 2: Clean the Area
  • Once the old door seal is removed, clean the area around the edge of the tub thoroughly. Use a clean cloth to remove any dirt, debris, or residue.
Step 3: Install the New Door Seal
  • Take the new door seal and align it around the edge of the dishwasher tub, making sure it sits properly in place.
  • If your dishwasher has retaining clips or fasteners, use them to secure the new door seal in place. Alternatively, press the seal firmly to ensure it adheres to the tub securely.
Step 4: Test the Door
  • After installing the new door seal, close the dishwasher door gently.
  • Check for any obstructions or misalignment of the seal by running your fingers along the entire perimeter of the door. The seal should be evenly and securely in place.
Step 5: Reconnect and test the power.
Connect the dishwasher to the power source after ensuring that the new door seal is correctly placed.
Run a brief cycle or just check for leaks while the dishwasher is running normally.
If you run into any problems or difficulties throughout the replacement procedure, review the dishwasher's user manual or call Electrolux customer service for assistance. Additionally, if you are unsure about replacing the dishwasher yourself, consider hiring a professional dishwasher repair service.
2answers
Fixing the springs on the door seal of a Fridge Freezer
no maker ,no model number told
and moved this from cars to fridge.
1helpful
How do I replace bottom door seal on Fisher and Paykel dishwasher DW60CC/CE
  1. Open the dishwasher door and remove any debris or old pieces of the seal from the door and the dishwasher.
  2. Clean the area thoroughly to ensure the new seal will adhere properly.
  3. Take the new seal and carefully line it up with the door, making sure it fits into the channel around the edge of the door.
  4. Start at one end of the door and work your way around, pressing the new seal into place and making sure it's seated firmly.
  5. Once you've finished installing the new seal, close the door and inspect it to make sure there are no gaps or misaligned sections.
  6. You do not need to use sealant or glue for the replacement of the bottom door seal.
Fitting new door seal
Door seals are in a formed groove/slot.Grab the one end and pull the seal out.Putting the new one in is harder.Use a light lubricant,like vasoline,that will just dissipate after a while,and gently pull the new seal into the groove/slot.I've had to do this myself.
How do I repalace a door seal on the Kenmore refrigerator?
Remove the door makes the job easier. Using a table lay the door with door seal in the upright position. Pinch and pull the door seal over to one side to expose the door seal screws. Remove screws and gasket/ seal and install the new door seal in the reverse order.
How do I change the door seal, the inside of the door looks like it is plastic welded to the outside, no screw of anything to seperate it. Thanks
. Very carefully , while looking at your door seal at the top of the door , peel it up from underneath , or from the bottom of the seal upwards and you should see the screws or retainer strip . If there is no screws or retainer , then the seal has a lip on the center of its base that runs all the way around the door seal. You won't be able to see it until you pull the seal away from the door . Start at the corner and pull the seal straight out away from the door and you'll see the lip which locks into a groove in the door self . Only do this once you have made sure there are no screws or retainer strips used . Once you pull the seal completely off the door , clean the groove with warm soapy water . Also , when installing the new seal , apply some warm soapy water to the lip on the new seal to aid you in pressing it back into the door . Here again , start at the corner and take your time . Be careful not to stretch the door seal as you install it . Good luck
3answers
Water leaking through the seals on my 93 mx5, what
buy and install new seals ar try and see if window is adustablie
1helpful
A HOLE IN THE RUBBER SEAL
You can certainly diy. Unplug the washer. With the door open, look at the bottom of the seal. You'll see a ring clamp. Loosen the screw and remove the clamp. Peel the seal inward. It is easier to complete the seal swap with the front off. Remove the door and set aside. Locate the screws for the front of the machine and remove them, gaining access to the seal. Youcan either set the door to the side with the door lock wires still attached, or unclip them, which is easier. With the seal folded inward, you will likely find another clamp at the bottom. Loosen this as well. Remove the seal and replace with the new one, making sure to orient it like the old one was, and fold it to the inside like you had the old one for removal. Replace the front panel. Complete the seal installation, being careful to make sure that the clamp removed earlier gets put back in the groove and seats well. Reinstall the door. Best Regards, --WoobieDog--
Top Traulsen Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
