Daikin heat pump, turn it on with remote, top green light comes on, vents open then close and unit does not work. Green light still flashes
  • 4,472 Answers
Can you give me the exact model number of the unit please?
Thanks,
Lee
Posted on Jun 29, 2008
  • Lee A.
    Lee A. Jun 29, 2008
    Hard to say without more info. There is a usually a reset button near the blower motors housing. If this was overloaded you can reset it wait 30 minutes if you ran it at all to make sure the motor is cool. Also
    Heat pump turns on and off too often
    If
    your heat pump cycles off and on too frequently, the problem is likely
    to be with the thermostat. See the thermostat-related problems below
    for information on repairing this problem. When a heat pump turns off
    and on too frequently, the problem may be that the unit is overheating
    because of a clogged filter or blower that is malfunctioning. Try
    cleaning or replacing the filter. If that doesn't do the trick, call a
    heat pump repair technician.
    That could be another possibility. Your best bet is to have a technician check it out.
    Thanks,
    Lee
    Guru:
  • 1,894 Answers
Just try leaving the unit plugged off from the main power for few hours.
then try switching ON.
What does a flashing light mean?
a flashing light could mean any number of things. normal operation, number of communicating components, a minor alert such as a filter change or major alarm like pressure error or control board problems. first we would need the number of flashes and /or sequence of multiple flashes AND the model number of your "split heat pump!"
Jan 13, 2018 | Heating & Cooling
Light 2 and 3 flash in the condenser outside in my mini split system dual zone AC/Heat Pump. My second floor AC unit does not work. Green light comes on, vent opens, green light flashes.
Flashing lights normally are an error code.. this could be anything really. You have to find out what that code is telling you (manufacturer specific). You most likely won't be able to fix this yourself if you can even find what that code means.. your best bet. Get the installer back. Unless you did it yourself. Then your gonna pay a lot for service unless you find someone willing to look at it (not many people will look at systems they didn't put in.)
Otherwise you have a ugly box on your wall that wi?l only flash some lights at you..
Jul 19, 2017 | Heating & Cooling
Green light flashing On Daikin fvy453cbv1
how many blinks, look up daikin error reset or daikin factory reset to clear the codes and get into secret service test mode.
Jan 03, 2015 | Heating & Cooling
Daikin FVY125 U4
This is a communication issue between the indoor and outdoor units.
This fault can be caused a issue with the interconnecting wiring such as an induced voltage on the Communication cable or even if a Drain Pump has been installed incorrectly external to the Daikin Unit.
Ensure that the Outdoor unit has power to it and that the Main PCB has a Green Flashing (HAP) LED on it to show that it is powered up.
Jan 15, 2012 | Heating & Cooling
My daikin inverter does not turn on. when i press on on the remote, the flaps open all the way down then close. the green operation light is flashing.
Seek a refrigeration mechanic. With out looking at the unit it is to pin point problem.
More than likely a PC board issue on the indoor or outdoor unit. Does your remote control give you an error code. If possible look at the users manual on how to get the remote to give you the error code.
Nov 26, 2010 | Cfm Daikin R410a Split System Air...
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Heating & Cooling Logo
1,010 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
