Question about Dual XDMR-7700 CD Player
Not workin correctly
Wen i ground it all the lights come on except the power button and nothin plays .. wen i unhook the ground and plug the antenna cable in the power button light comes on but nothin else .... i cant figure out what the problem is...
  • Anonymous Apr 03, 2009
    all of the lights come on but you cant hear anything.. ive checked the wires 3 times... i have seen it work before but idk why it wont now can someone help!!
    Problem Solver:
  • 8 Answers
CHECK SPEAKER WIRES , SEE IF YOU CROSSED A GROUND BY ACCIDENT
Posted on Jun 29, 2008
I have a 2010 huyndai elantra. My radio isn't working. It powers on but no sound. I don't have a reset button and I've unhooked my battery for 10 min and still nothing.
Has someone worked on the antennae lately? The antennae completes the ground...be sure it is still plugged in to the back of your radio...hope this helps.
May 25, 2016 | Cars & Trucks
Im not getting any power to it
hi lizzy, please make sure that the power wiring (red, black and yellow cables) of your unit is correctly connected to the vehicle. next check if the blk wire(ground) is connected to the chassis(metal body part) of your unit (use a mutimeter). if not then attach a wire from the body of your unit to the blk wire. also make sure that your antenna lead is connected to the unit, and that the antenna is securely grounded to the body of vehicle. once power is correctly connected your unit will light up a red LED light in the power/source button. if all this does not help it will be advisable to have unit checked at jvc service center. cheers!
May 22, 2012 | JVC KD-G110 CD Player
Handset just blinking red light
You need to connect the phone to your pc without the battery install and open up your blackberry desktop manager.....go to application loader and update the phone's OS , this should correct the problem :)
if it does not work let me know but this method have not failed me yet nor my customers/
Mar 25, 2009 | AT&T Blackberry Curve 8300 Smartphone
My hard drive power supply aint workin
first off all does pc detects it as an IDE drive?
Mar 11, 2009 | Maxtor Hard Drive
Kenwood KDC-MP438U acts as if there is no power to it,dead nothin
The speaker wires are very sensitive. You need to make sure that they are not grounding out. Once the unit senses this it will shut off. Pull the plug out of the back and start over.
Dec 30, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
Radio Blowing Tail Light Fuse
by the way you tell me that the radio illumination is the gray wire and all of the rest you are wrong. try the correct way red is key positive,yellow is constant power,black is ground,orange is illumination,blue is remote,gray is right front positive and gray black is negative,white is left front positive and white black is negative,green is left rear positive and green black is negative,violet is Right rear positive and violet black is negative,
Nov 23, 2008 | 1993 Oldsmobile Cutlass Ciera
NEC Projector
they have a fuse on the power board inside the projector itself, But normally the fuse does not go bad unless their is a dead short in the unit.
Dec 13, 2007 | NEC MultiSync MT830 Multimedia Projector
Mine is actually a q4000 4 channel amp
First of all, you MUST HOOK UP YOUR GROUND WIRE FIRST. You may have damaged it if you hooked your power and trigger wire first and then the ground wire. Unhook EVERYTHING except the hot wire, ground wire and trigger wire. If you still can't get the unit to come on then it is time for a trip to the repair shop. Good luck.
Feb 01, 2007 | Cadence Q200 2 CHANNEL POWER AMPLIFIER...
Dual XDMR-7700 CD Player Logo
82 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
