My V172RTNRA 17 in. LCD just started to trobe at all times. It does this on all ports. The PC, TV input, S video and RCA. They all just strobe and I have no idea which part to replace or where to get them.
I solved my problem when I tried using a different Power supply. The Batesias V171RTNRA uses a 12V 4.2Amp positive center post power supply. I discovered that I had a 12V 3.0Amp power supply that had belonged to a hard drive and decided to give it a try.
It worked like a charm. Something had gone bad with the original Power Supply causing strobing in the picture. With the replacement Power Supply it no longer strobes and works perfectly.
I am not sure if it's the lower Amps that solved the problem or not.
Was this helpful?
Yes
No
Popular Solutions for Batesias V171RTNRA 17 in. LCD
The controls on my television no longer work. I can get the TV to turn on but then can not increse...
(More)
The controls on my television no longer work. I can get the TV to turn on but then can not increse the volume or adjust anything on it. I've changed the batteries in the remote. I've used th controls on the Tv itself but for example the volume will turn up and then it turns itself down immediately. Help
When we mounted our LG tv on the wall the original factory base that acts as a stand was thrown...
(More)
When we mounted our LG tv on the wall the original factory base that acts as a stand was thrown away. Now it's coming off the wall and i need that stand! Where can i get one?!
