Question about GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH
Need help w/the coldness of our upright
Recently bought this upright used. I don't think it's exactly like the one above, because it's not frost free. However, we defrosted it and then plugged it in. It wasn't on the next day and we thought we had put it in a bad plug in our garage. Plugged it in that day and heard it kick on and left it to get cold. The next morning it wasn't cold, cranked it over to 7 and left it again (the top shelf did have a shimmer of frost on it, but it wasn't cold enough). Today I turned it down to 4 to see if I could get a difference and still can't get it cold. It didn't come with a manual and I'm unsure which number is the coldest and what I am doing wrong. It was cold and ice covered when we went to look at it and buy it. Please help!
    Novelist:
  • 161 Answers
It sounds like a freon leak. This can happen when moving it. I don't recomment fixing it. You can get it charged again and it will work for a while. This will cost you about $75 - $100. You can't do this yourself as you have to be certified to buy freon. The reason I don't recomment fixing it is because when it goes out again you will lose all food. Since it is a freezer you probably don't open it every day and you might not notice that anything is wrong. Try to lay a guilt trip on the seller and see if they will take it back.
Posted on Jun 30, 2008
What number should i set the upright freezer control
Thank you for your inquiry, friend!
Normally it is recommended to set your Frigidaire upright freezer to zero degrees. It is your option to make it cooler if you choose too. I hope this information has been helpful. -Matt
Oct 15, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Frigidaire upright freezer model# ffu20f9gw3. The temperature alarm light is on. Cold air is blowing but the ice cream melted, and the hot dogs are still frozen and loaves of bread that i...
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
Aug 13, 2010 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
I have a 4yr old 13.7 cubic upright frigidare freezer. Running all the time, I defrosted it recently (only minimal frost/ice on base behind basket) after noting top shelf warmer than others and food...
Hi, Put a thermometer in the freezer and see if it gets down to 0 to 5 above zero. If it is not getting that cold, something is wrong. If you had frost building up behind the rear panel, there is a defrost problem.
Please let me know the temperature and I can assist you further.
Vic
Jun 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
I bought a used Kenmore upright freezer, it's been running all the time.
The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
Jun 02, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore Frost Free Comm. Model #253-23425100 - will not stay cold
Two things:
Either the thermostat has inadvertently been turned up, (too warm) or the gas in the compressor tank is low. If it isn't #1, call a repair tech to replentish the has in your compressor. If that isn't it he will tell you what he thinks it is. Good luck!
Mar 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH Logo
102 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
