Hi
Ii am woundering where i can find electrical sheet for my printer samsung laser ml-2151N, because 1 mouse come into and it damage some part inside on SMPS and HVPS board. Thank you
Re: Hi
Ii am woundering where i can find electrical sheet...
Hi Friend, Do you know that behind every problem, there is always a solution. So therefore, I have quick, easy and real solutions to your Printer Problem. Just click here for you Solutions.
I hate to say this, but there's nothing you can do, these printers are notorious for printing blacks as grays. On the bright sde your toner will last forever.
lsu stands for laser scanning unit. it tansfers the image onto the transfer drum, common problems are horizontal sync, i would suggest a replacement lsu
ensure you have the correct driver installed. it may have a slight variation in the driver name for duplex printing. ie. the driver name may be ML-2151NT-D.
Inspect and clean high voltage power supply contacts. The HVPS contact springs mounts on the high voltage power supply PCA and protrude through the toner cartridge cavity to contact the toner cartridge. Verify that the contacts are not dirty or corroded, and that the spring action is functional. If dirty, clean using dry, lint free cloth. If this does not work, use a minimal amount of alcohol.
It could also be the HVPS. I hope that solves your Problem, If so kindly accept it. Thank You, Arjun.
The problem is that the cartridge you re using was reloaded with toner, but the remanufacturing process did not include replacing the chip. The ML2150 and the 2151N do not read the toner's chip on boot, but the 2152W does. So you either have to get a cartridge that has a new chip or get a new, genuine, Samsung cartridge.
