Question about Cameras
I have a Sony Cybershot DSC-W80 that's acting up. When I turn it on, the zoom/lens moves in and out four times. Then, the screen displays "Turn the power off and on again." When the power is shut off the zoom/lens move in and out two times before shutting off. This occurs every time.
  • 1,894 Answers
Does it also show a lens error or any E18 error??
have you dropped it anywhere recently??
did you try a hard reset?
Posted on Jun 29, 2008
  • dewan nafees ahmed Jun 29, 2008
    There is a motor assembly that is part of the lens assembly in the
    Inside this motor assembly there are a few custom gears that
    are hard to find.
    When a gear gets damaged, the camera is able to
    detect the motor spinning and monitor that the lens is not moving.
    causes that error message to display on the screen.
    on the extent of the damage of the gear and which gear broke (their are
    two typical ones, which are replaceable), some users may be able to get
    passed this occasionally.
    This can occur if only 1 tooth of the gear is
    broke. Eventually the teeth next to the broken tooth will break because
    of how the gears are connected to each other.
    This usually can be
    noticed by a grinding noise when you turn on the camera. If all you
    hear is a motor humming, then one of the gears is damaged as well.
    the fix depends on how the gears where damaged. If the gears were
    damaged because the camera was dropped on its lens, it could be
    possible that the lens itself is now crooked and even replacing the
    gears will not fix the problem (the lens will physically get stuck and re damage the replacement gears).
    If the gears broke over normal use , they can be replaced and all should work
    hope it helps.
    thank you
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
DSC W80 Error Message - Zoom and Picture Doesn't work
There is something blocking the sensors for the lens position. This can something as small as a piece of sand. The motors and gears that move the lens are very small and delicate. You can send it in for repairs to
Nov 24, 2013 | Sony Cybershot DSCW80 7.2MP Digital Camera...
When I turn it on the screen stays black until I
  1. Ensure the camera is turned on.
  2. If applicable, ensure the lens cover has been removed before taking pictures.
  3. Ensure the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. NOTE: Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon [FIG. 1]. This button could be a standalone button or incorporated as one of the control arrow buttons depending on the model of camera.
  4. If operating the camera with a battery, ensure the battery is fully charged.
  5. Ensure the battery is inserted properly in the camera.
  6. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  7. Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
  8. Perform a reset procedure on the camera.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony Service Web site at can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Try to reset the camera to original settings:
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jul 25, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Does the sony cybershot dsc-w80 have the capability to take still shots? I can't find my manual
Please use the link below to download the user manual for your camera
Please read page 21. You need to turn the "mode dail" to P or anything except move recording.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 29, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Problem with sony cyber shot dsc- w80
I jeremy- i was having the exact same problem today. I phoned Sony repair, who then had me take out the battery and hold down the power button for about 30 seconds..reinsert the battery and power up. Didn't fix it. I came home and read some posts on here. I ended up trying the gently twist the lens as it was zooming in and out..I twisted a little and pulled a little. About the third time, it worked. (I also held the power button down with the battery in, just to try..maybe that helped, too). Sony wants flat fee of $91 to that what they told you?
Jun 06, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cybershot DSC-W80 Blurry Photos
I think turning the face recognition off will fix this.
Apr 02, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Cant zoom on my DSC-W80 sony cybershot after droping it in the sand at the beach
If you found good information in my solution, please be sure to rate it! Thanks!
Oct 25, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Cybershot DSC W80
Can you please send me copy of dsc w80 software cd - if its too large to email, zip and store at or other file storage site.
Apr 14, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Cameras Logo
132 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
