Question about Panasonic Lumix DMC-FZ7 Digital Camera
Problem taking pictures after number 48 is shot.
I have a 2 GB memory card installed and the first 45 or so pictures are stored ok on the card but as soon as I try to take the next few the camera acts as if it took the pictures ok but when you try to view them the display is blank. I took the card out and placed it in a reader on my PC and still cannot read the pics. The card formated ok and cannot tell if its the camera or the card. Any one else had this type of problem?
Thanks
Don
Are you using a panasonic SD card? The camera may not function properly when a cheap SD card is used.
I also have a FZ7 and it works better with a memory card of the same brand.
Also, if the card or the camera are old, they may be worn out.
Posted on Jul 09, 2008
How can i change number of pictures i can take
Your camera has only 10 MB available for picture storage using internal memory. An SD card of even 1 GB (tiny by today's standards) will hold 100x as many picture as your internal memory. If you already have an SD card,
1) Buy a larger memory card. These don't cost much and an 8, 16, or 32 GB card can hold a LOT of pictures.
If you want to increase the number of pictures you can store either with the current card or using internal memory, then you have a couple of other options. 1) change the picture size. Menu -> then up/down arrows to select Picture Size. Press the OK button. Select the option you want (6.1 MP, 5.4 MP, etc). Press the OK button.
Feb 26, 2011 | Kodak EasyShare C633 Digital Camera
I can only take at least 15 shots in my Cannon Powershot A590 IS, pls. help me how to adjust for me to take pictures atleast hundreds of shots.
Your camera has limited storage using internal memory and probably came with a 32 MB memory card. An SD card of even 1 GB (tiny by today's standards) will hold about 100x as many picture as your internal memory.
Buy a larger memory card. These don't cost much and a 1 GB card can hold a LOT of pictures. After 1 GB, there are differences in the memory cards and the higher capacity card might not work in your camera.
If you want to increase the number of pictures you can store either with the current card or using internal memory, then you have a couple of other options. 1) change the picture size to "small" and 2) set the compression to "normal" to achieve the maximum number of images for your memory. Warning: small and normal might give pictures that are too low of resolution for what you want.
Jan 27, 2011 | Canon Accessory Outfit Case Flash Memory...
Message on screen no memory space in internal memory what does this mean
Hello. Your camera has 32MB of internal memory to store pictures and it's full. Your camera uses the Memory Stick ProDuo memory card and their available in various sizes. A 1 or 2 GB should be fine and will store several hundred pics.
builderdale
Jan 19, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
It stopped taking pictures, I purchased a 2 gb
I just inserted a memory card and the camera started working again.
No more problems.
Dec 04, 2009 | VistaQuest VQ-5115 Digital Camera
I have a Kodak Easy Share C310. It keeps saying that the internal memory card is full. The card is the camera is 200 photos yet it is only showing the original 16! Thanks, Kathy D
"internal memory card is full" There is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the Picture Size setting you have selected on your camera.The following are approximate number of pictures you can take at each setting: 4.0 MP: 16 pictures 3.1 MP: 18 pictures 2.8 MP: 20 pictures 2.1 MP: 29 pictures 1.1 MP: 48 pictures Internal Memory?the camera always uses internal memory, even if a card is installed. Auto (default)?the camera uses the card if one is in the camera. If not, the camera uses internal memory Image Storage Choose a storage location for pictures and videos. To correct the issue your getting follow this steps: 1.Press the Menu button. 2.Press to highlight the setting you wish to change, then press the OK button. - The settings you need to look for is Image Storage 3.Choose an option, then press the OK button. - The option you need to choose is Auto the camera uses the card if one is in the camera. 4.Press the Menu button to exit.
Nov 15, 2009 | Cameras
What does Frame No Full mean?
If you look at the top right of your camera screen when reviewing pictures you should see the frame count. As yours is reading "Frame number full" the count should be reading 999.9999 so you need to reset to 100.0000. How to do this is posted in my tips section of my profile under "THE ONLY WAY I KNOW HOW" I have pasted the section below.
Cheers
FRAME NUMBER FULL!!
If you get this message on screen then your counter has reached 999-9999 and the camera will not take anymore pictures until you reset the counter to 100-0001.
To do this follow the instructions in your manual or read on my friends...
Firstly, make sure you have a picture card inserted into your camera and you have saved any pictures on it to your pc because you are about to format the card inside the camera and you will lose any pictures you have stored on there.
Ok. turn your camera on and press the menu/ok button and select "SETTINGS" from the menu.
Scroll through the menus until you find FORMAT. Select this and you will be asked if you would like to continue. Select OK.
Depending on how large your card is (16mb - 1,2 gb etc) will determine how long this will take but it's not very long.
After you have done this your card is now wiped clean of memory and has been formatted to be used for your cameras software.
Next, select FRAME in the SETTINGS menu and set your camera to RENEW and press OK.
Now come out of your menus and take a picture.
Review the picture taken and check the counter reading in the top right of the screen. It should now read 100-0001. The counter has now been reset.
Now go back into your menu and select SETTINGS again and scroll down to FRAME once again. Set this back to CONT (continuous) and press ok. Your camera should be reset and you can now use it.
Note: If you have more than one card you will have to reformat each card because the camera will store and recognise the frame numbers stored on the card and continue using them rather than set them to 100-0001 or will open a new folder on your card and start using this as the new one thus taking up more space on your card reducing the number of shots you can store on it
Sep 30, 2009 | Fuji FinePix F40fd Digital Camera
How do i transfer pic from the internal memory to the memory card
www.kodak.com/global/en/service
FOR MANUAL DOW[section title] Choosing Internal Memory or SD/MMCCard
The camera offers two options for storing pictures and videos:
Internal Memory —Store pictures and videos in 16 MB internal
memory.
SD/MMC Card —Store pictures and videos on a card. The number/length
of pictures/videos depends on the size of the card. Purchase accessories at
a
dealer of Kodak products or visit www.kodak.com/go/dx6490accessories. For
storage capacities, see page 114.
Managing Your Storage Location Setting (after inserting the card with power
OFF)
1 Turn on the camera.
2 In any still or video mode, press the Menu button.
3 Press to highlight Image Storage , then press the OK button.
4 Press to highlight an option, then press the OK button:
Auto (default)—the camera uses the card
uses internal memory.
Internal Memory—the camera always
installed.
5 Highlight Continue, then press the OK button again.
The setting remains until you change it and applies to all camera
functions.
6 Press the Menu button to exit the menu.
NLOAD.
Jul 09, 2009 | Kodak EasyShare C643 Digital Camera
Memory card assistance
i don't know what year or model camera but 4 gb basically only work in 2 yrs or newer models-not all cameras support card due to diferent file format on sdhc cards-try going back to 1 or 2 gb and play it safe if they work
May 27, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
2 GB memory card for digital camera
The number of pictures that a memory card will store will depend completely on the file size of each picture. 750 pictures on a 2gb memory card would be around 2.5mb average each picture, which is more than adequate for basic shots - with a higher resolution the picture size can easily exceed this. Here is the link for the user manual for your camera; http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00261/DX7440_GLB_en.pdf Check page 20 - explains how to change the picture taking settings including the resolution/ file size. Also check page 53 - it explains the storage capacity of different memory cards at different resolutions. The manual suggests that the camera can only deal with a maximum card size of 512Mb, so it is possible that although a 2Gb card appears to work, the camera can only utilize the first 512Mb of the card. Hope this helps, please ask again if not :)
Apr 11, 2007 | Kodak EasyShare DX7440 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
46 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
