Question about Palm TX Handheld
I can not turn off my Palm
I tried to hot sync. Now it has the red dot Palm and the black dot Palm that keeps going on and off.
  • Anonymous Jul 08, 2008
    This is clement916. "My Premium Problems" please help
No idea
Posted on Jun 30, 2008
    Problem Solver:
I realy don't know. I guess I kept pressing the reset spot on back and the Palm went off from no activity after a while and when I turned it back on it worked. I also found out at that time that the computer lost all my Documents to Go. I will contact HP and find out what is wrong before I try to see about the Palm.
Posted on Jun 29, 2008
Palm cantro keeps hot syncing can not use my phone
this has also happened to mine like yesterday, dont remove the battery mine wont turn back on now, try letting it charge overnight withoout touching it at all
Oct 23, 2009 | Palm Treo 500 Centro
Palm centro goes into hot sync mode
IN PREFERENCES GO TO PERSONAL/BUTTONS THEN AT THE BUTTON LOOK FOR HOTSYNC PRESS IT THEN ON CABLE CHANGE IT TO PHONE; IT MIGHT BE THE PHONE HAS A PROBLEM WITH THE HOTSYNC CABLE CONNECTION. NOW IT DOES GO TO HOT SYNC INSTEAD IT GOES TO PHONE. NOW I'M TRYING TO FIX THE PROBLEM BUT MY PHONE STILL USEFUL.
SORRY ABOUT MY ENGLISH
Sep 14, 2009 | Palm Treo 500 Centro
My phone will not turn on
Hot sync the phone, clean the battery contacts (touch of alcohol on a q-tip), and try a soft restart...which is simply pulling and reinstalling the battery.
If it does it again, you may have a corrupt application. Hot sync the phone, do a hard restart (pull battery, reinstall battery, hold down power button until black bar crosses bottom of screen, select "yes" to reformat, and re-sync the phone to reinstall the software and data.
If it continues to be a problem, you can try replacing the battery or removing user-installed applications one-by-one to see if the problem clears...but the problem is most likely an unstable phone.
Sep 11, 2009 | Palm Treo 500 Centro
My Centro started hot syncing itself.
try this: take the battery out, then hold down the red power button...keep holding it until you put the battery back in and your screen comes on. Hope this helps, it worked for my daughter's!
Jul 21, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
How do i transfer my pictures from my palm centro to my computer?
use the palm quick install and browse through picture files and add them. You will need to first of all put the hot sync cable on your phone then hit the button on the cable connector, give it some time, if you still cant do it, read below
if it says it cant connect, go to hot sync on the home and then below the hot sync button ON THE SCREEN, Where you see switch the IR to a PC/handheld click it and go to the second option. If that still doesent work, on your PC go to all programs then look for palm, go to that file and click hot sync now the hotsync is turned on the computer then after that do all the steps in the first paragraph.
thank you
Apr 07, 2009 | Palm Cell Phones
By typing hot Sync my palm makes a restart
Try this, uninstall your current version of Palm Desktop, then go to this link on the Palm support website http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/home/page_en.html this will give you the link to the download for the TX version of Palm Desktop, this may or may not fix your particular problem but it is worth a try.
Mar 24, 2009 | Palm TX Handheld
My TX crashes every time I try to hot sync
You could delete that app if you want, however I would go into hotsync config and sync only one section at a time, such as Notes, but not contacts or calendar (or anything else). If it works then add a section, such as contacts. Keep adding sections until it malfunctions. Pimlico software makes a product dbfixit ($) that can fix database (blob errors). You can download and install it, and it will report on (but not fix) any errors it finds.
Feb 04, 2009 | Palm TX Handheld
Hot sync
Try reseting the palm.
Jan 02, 2008 | Palm Treo 680 Smartphone
Palm T/X won't hot sync on Window XP Media Center Edition
i had that problem too. sorry it is bugging you.
i know you probably want to sync your data rught now. So for now try to disable the syncing of documents to go (just for now)
on palm desktop, look for the conduits and temporarily disable the syncing of docs to go. Also ensure you plug in your pda charger as well as the usb cable (I found out this helps through experience) and sync. (Just to back it up)
as for the documents to go, there is probably a file(document) that is generating the errors. please look through documents to go on your palm desktop and remove any file you feel is not necessary. also take note that it is best if your pda has some free memory on it. you may want to save those documents on a disk (If you are not already that is..) clearing up ram made my tx more stable esp during hot sync.
please let me know it that worked for you. i still have some suggestions
good luck and enjoy
Nov 05, 2007 | Palm TX Handheld
Palm TX Handheld Logo
74 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
