Question about Metz Mecablitz 60CT4 TTL Flash
Flash does not fire consistently
My flash does not fire consistently and causing me a lot of anguish. I have had it for four years. Just replace the sync chord and the connector cords and the problem still persists.
What is wrong with my flash? If it needs repair who do you suggest is the best to fix the problem
I need help.
  • 1,879 Answers
Greetings,
Ritz Camera is the best.
You're very familiar with your camera and already performed initial troubleshooting by replacing the common/obvious part.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 29, 2008
    Guru:
  • 1,894 Answers
Yes the flash needs a repair from the company directly
  • dewan nafees ahmed Jun 29, 2008
    this delaying in flash is the problem with the timing circuit.
    replacement of sync cords is not a solution for this problem.
    this is the problem with improper timing of the signals.
    this happens due to improper discharge of capacitors or can be due to failure of some components.
    since this repair needs the attention of a experienced tech i would request you to take it the authorized service centers.
    they can help you solve this problem better
    good luck
    thank you
  • 3,037 Answers
Have you tried replacing the bulb at all or check to see if it may be loose or not have a good connection which may cause it to work sometimes but not all of the time
The ACMP function doesnt work when I play, even tho it says it is on in the display window
Check you have selected 'sync start'. The ACMP selection activates the automatic chords but not the rhythm, so each note produces a droning chord. Sync start activates the automatic chords and rhythm you have selected when you play anywhere near the bottom end of the keyboard. Alternatively you can manually press play to start the drums by themselves and then the chords will begin the moment to play with your left hand.
Mar 12, 2015 | Yamaha PSR-E413 Portable Keyboard
I have fire to the coil but not to the plug on a 1985 Honda four wheeler. Can you help me?
If you have fire to the coil but not out out of the coil, the coil is usually bad. However on mid 80's Hondas, there is another common, but little-known cause. The connector on the wire going to the spark coil gets loose, corroded or both. Pull the connector off and inspect the tab connector on the coil. This connection has to be the cleanest and best connection on your cycle. If the connector tab on the coil is not shiny, polish it with emery cloth and push the connector back on. If it is not the tightest connection on the Atv, squeeze the female connector so it makes a tighter fit when you push it on.
BTW in my experience, this is the leading cause of ignition failure on Hondas more than 20 years old with with CDI ignitions.
R. Liston, engineer, formerly with Honda America.
Oct 02, 2014 | Honda Motorcycles
In iphone4 speaker sound not working
The speaker is sometimes disabled when you connect the 30 PIN sync chord. If the 30 PIN connector is damaged, it can cause the speaker to not work, or to work intermittently. Try using a thin object (like a safety pin or something similarly thin, preferably something non metallic and non conductive) and gently jiggle the 30 PIN connector on the iPhone while playing a sound, (like a music file in the music player). If the sound starts playing again you have found the cause of your problem. Unfortunately if the connector is the problem you will need to be careful in the future when you disconnect your sync chord.
This is most often caused by placing the iPhone into a sync port designed for the iPhone 3GS and earlier models. The iPhone 4 and later needs support to keep it from straining the 30 PIN connector on the iPhone 4 or iPhone 4S.
Good Luck.
Apr 08, 2014 | Cell Phones
Vivitar 285 HV won't fire
If you know basic soldering, Open the old hot shoe from base
(4 screws).Note down the position of the wires.
Try to fire the flash with shorting two trigger wires,most ly it will fire.
If the springy contact is adjustable do it.If it is not repairable, you can get metal hot shoe from ebay easily.
Caution: metal hot shoe will short circuit 4 TTL contacts (on digital camera) ,so you need to put cello tape at bottom of hot shoe with only center hole.
Hope this solves.
May 12, 2009 | Vivitar 285HV Flash
Sunpak 383 problem
Try to trigger it by shorting Center of shoe mount and the side terminal with a small wire.If it is firing the flash is ok.
If not there is open connection in the sync jack ,due to repeated inserting of sync chord.The springy part inside is not going back to its normal position.
You can fix it your self by opening it(adapter only)
.If you are new to this take a photo of the wiring immediately after opening the shoe adapter to see the position if any wire breaks later on.
Do not give up .383 is great flash
Nov 05, 2008 | Sunpak 383 Super Flash
Power chord
get a power cord as it would be less expensive because if the connector on your system is faulty you may have to spend a lot of monet
it happen with the power cord that they go gad
so don'y worry about that
Jun 10, 2008 | IBM ThinkPad T43 Notebook
SB800
When you attach the flas to the camera can exidentli fire. This is normal, and manufacturer recomendation, turn off the flas unit before attach or deattach, prevent this fireing. Fireing when you turn the flashead is not normal. Probably the mounting foot of the flash unit can move in the hotshoe, breaking connections between the connector pins, causing exidental fiering. Always lock the locking lever of the flas, wich can prevent this unwanted movement. Also chek the hotshoe on the camera, wich should to have a "leaf spring" keeping the flash unit steady.
Dec 07, 2007 | Nikon Speedlight SB-800 TTL Flash
550ex PC sync socket conversions
I do medical/photo equipment repairs & IR conversion, but I'm in the USA.
Over 20 years and Canon knew about that problem including many photographers. Most of Canon flashes can not do manual or aperture mode because they have to flash sensor.
Now they have it on the 580EXII. I guess Canon has no photographer working in the flash department.
Canon screwed photographers, buy a Metz, Vivitar, Sigma, Sunpak, or NIkon.
Alexander
atdlee@netzero.com
Nov 27, 2007 | Canon Speedlite 550EX TTL Flash
Studio Strobe not firing with Coolpix
The Coolpix line of cameras require a "tip positive" sync connection to an external strobe unit (when using the Nikon AS-15 Flash Sync Adapter). On some external Studio Strobe units the sync polarity is easy to change because of the type of plug: On this type of connector simply turn the plug around and insert it with the male pin connectors in the other holes. Other types of connectors (such as the standard "phono" plug) are not generally changeable by the user. If the Coolpix does not fire an external strobe check with the strobe manufacturer for sync polarity info.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Metz Mecablitz 60CT4 TTL Flash Logo
Top Metz Cameras Experts
Doberman
Neil
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
