Question about Shuttle MV43VN Motherboard
No video with p4 cpu specs 2.8ghz 533 fsb 1gb L2 cache Prescott
I put the cpu in my motherboard, turn on the system, the power comes up
but no video comes up on my monitor, normally I have a celeron processor, in the system specs on the celeron is this 2.6ghz 400 fsb
128k L2 cache and the system works great with that cpu, could this be a cpu problem, or my motherboard does not support the prescott CPU?
  • 28 Answers
2 years and not a single answer? It is most likely was compatibility issue. but It could also be a BIOS issue... if your still trying XD pull out the battery on the motherboard for 5 or 10 minuets
Posted on Aug 31, 2010
    Genius:
  • 1,066 Answers
Maybe you need to update your bios, in your case, if the processor fits, then it should be supported.
Posted on Mar 11, 2009
2 Suggested Answers
compdoctor20
  • 172 Answers
SOURCE: upgraded cpu- wont boot
Teresa, if you changed the front side bus to 533, your memory must have the same clock speed. Memory clock speeds are what is known as "backwards compatible" but not forwards. This means that you could put a piece of memory of a clock speed of 400mhz into a system that runs at 333mhz and it will "downclock" the memory, but you could not put a piece of 333mhz memory in a 400mhz fsb pc and expect it to run. one of two things will happen, the system will not boot at all or the syetm will downclock the processor to a slower speed. In your case your cpu must be 533mhz clock speed with pc4200/533mhz memory to function correctly.
compdoctor2005@btinternet.com
Posted on Dec 13, 2008
CAN NOT SUPPORT 2.8/1MB/533
That's because your motherboard only supports Northwood chips that have a L2 cache of 512 K. The chip you are trying to use is a Prescott chip with 1MB of L2 cache.
Your best bet would be to buy an INTEL Pentium 4 3.20GHz/512/800 Processor SL6WG Socket 478. It is a Northwood chip with an 800 fsb and has hyperthreading. There is a 3.40ghz model, but you can get the 3.20ghz chip much cheaper.
Here is your motherboards specs page:
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-51078
May 19, 2012 | IBM ThinkCentre S50 8183 - P4 3 GHz...
CAN NOT SUPPORT 2.8/1MB/533 PROCESS
Here's your motherboards specs page:
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Can prescott 800 mother support p4 2.4ghz/1m/533 processor
The MSI 865PE Neo2-PLS
Supports Intel® P4 Northwood/Prescott (Socket 478) processors.
FSB 400 (for Northwood only), 533, 800MHz.
Supports up to 3.2GHz or higher speed.
See page 1-2 in your manual. Also see page 2-3.
MSI supported CPU list; http://www.msi.com/index.php?func=prodcpusupport&maincat_no=1&prod_no=569#menu
Main link for 865PE Neo2 platform; http://www.msi.com/index.php?func=searchresult&keywords=865PE+Neo2
Cheers'
Mike
Jan 20, 2010 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Trying to upgrade cpu.
Here's a direct link to the service manual of the NetVista 8303-21A:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/netvista_pdf/24p2969.pdf
On page 13 of this manual:
Microprocessor (varies by model type): Intel® Pentium® 4 processor with 256 KB or 512 KB of internal L2 cache memory and Intel NetBurst™ micro-architecture.
It seems that the computer's motherboard does not support Intel P4 processors with more than 512 KB of internal L2 cache. That's why your P4 2.8GHz/1M/533 Prescott processor did not work.
You will have to either buy another processor with 512 KB L2 cache, or replace your motherboard with one which supports the new processor.
Dec 19, 2009 | IBM NetVista PC Desktop
Cant run 3E GHz 800 FSB L2 cache 1MB cpu on a ASUS P4P800s-x
here are the specs.
CPU FSB DDR DIMM Type Memory Frq.
800Mhz PC3200/PC2700/PC2100 400/333/266 Mhz
533Mhz PC2700/PC2100 333/266 Mhz
400Mhz PC2100 266 Mhz
the CPC and the moemories meets these spec. then you shouldn't have problem.
since you didn't spec the meories. I am assuming that the meories are within specs.
but, from what you say about, I suspect the memories is not up to part. looks like the meories are in PC 2100 range.
Nov 14, 2008 | ASUS P4P800S-X (610839118175) Motherboard
ASUS P4S333-M What is the maximum CPU this bouard will run
P4S533-MX
The following table shows the support for CPU / Motherboard
CPU
Since PCB
Since BIOS
Note
Celeron 1.7 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 1.8 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.0 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.1 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.2 GHz (400 FSB, L2 cache:128KB) ALL
ALL
Celeron 2.3 GHz (400 FSB, L2 cache:128KB) ALL
1005
Celeron 2.4 GHz (400 FSB, L2 cache:128KB) ALL
1005
Celeron 2.5 GHz (400 FSB, L2 cache:128KB) ALL
1006
Celeron 2.6 GHz (400 FSB, L2 cache:128KB) ALL
1006
Celeron 2.7 GHz (400 FSB, L2 cache:128KB) ALL
1006
Celeron 2.8 GHz (400 FSB, L2 cache:128KB) ALL
1006
P4-1.4 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.5 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.6 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.6A GHz (Socket478, 400 FSB, L2 cache:512KB) ALL
ALL
P4-1.7 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.8 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-1.8A GHz (Socket478, 400 FSB, L2 cache:512KB) ALL
ALL
P4-1.9 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-2 GHz (Socket478, 400 FSB, L2 cache:256KB) ALL
ALL
P4-2.20 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.26 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.40 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.40B GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.50 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.53 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.60 GHz (400 FSB, L2 cache:512KB) ALL
ALL
P4-2.66 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2.80 GHz (533 FSB, L2 cache:512KB) ALL
ALL
P4-2A GHz (Socket478, 400 FSB, L2 cache:512KB) ALL
ALL
P4-3.06 GHz (533 FSB, L2 cache:512KB, HT, C1/D1) ALL
ALL
Since PCB 2.0 or later support HT Function
Jun 22, 2008 | Computers & Internet
Processor compatibility
looks like you limited to the p4 Prescott, this is a p4 list of the cpu support from asus. I also looked at their bios update page and found no bios improvement. if you can move to the 775 platform ,you can move from p4. otherwise, the p4's are still  good . I had the cpu that is the 2nd one down. 3.2ghz oc'd to 3.8ghz full time with a max of 4.0ghz on air[775 platform] quad-pumped gave me a 1001.3mhz FSB
Supports Intel Prescott CPU
P4-3.20E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   ALL 1006 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1)   ALL 1011 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:512KB, HT, D1)   ALL ALL gogo.gif
P4-3.40E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   2.00 1006 gogo.gif
P4-3E GHz (800 FSB, L2 cache:1MB, HT, 90nm)
SEE 4 YOURSELF
http://valid.x86-secret.com/show_oc.php?id=156822
Oct 30, 2007 | ASUS P4P800 SE (890552603657) Motherboard
Are all P4 478pin cpu's compatible with the P4mm2 motherboard?
Just in case your pins are only bent you can straighten them out as long as you are careful. Take a mechanical pencil without lead (.5 works ok but .7 may be easier to use) and ground it by touching it to your power supply. Then work the CPU pin slowly into the pencil and slowly bend the pin up. If you?re patient and careful you can usually straighten out any pins that have been bent. You didn?t stat which version motherboard you had. On the P4VMM2 (V1.3) motherboard the manual states that the motherboard will automatically determine the CPU clock and system buss frequency and makes the appropriate changes. The manuals only references a front-side buss limitation of 400 MHz, however, a FAQ from the manufactures support site says the V1.x motherboard?s CPU is limited as follows: - Pentium 4 400Mhz FSB (256K/512K L2 cache) CPU ? 2.6GHz - Celeron 400Mhz FSB (128K L2 cache) CPU ? 2.6GHz I would stick with the FAQ recommendations if you have to purchase a new processor, that or contact the support line to verify. Make sure you point out the FAQ on their site since they will probably just refer you to the manuals specs. P4VMM@v1.x CPU FAQ: http://www.ecs.com.tw/ECSWebSite/Support/FAQ_Answer.aspx?FAQID=3010023&MenuID=65&LanID=9 Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 14, 2007 | EliteGroup P4VMM2 Motherboard
Shuttle MV43VN Motherboard Logo
341 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
