Question about GE PFS22SBSSS Stainless Steel French Door Refrigerator
Ice maker spills ice
The ice maker in the bottom drawer freezer spills ice all over the bottom of the freezer and on the floor under it when you open the drawer with ice in it. Is there any way to keep this from happening?
  • 2 more comments
  • Sipe Jun 30, 2008
    The icemaker dumps it into the bin but the bin is so shallow that when you open the drawer the ice spills all over. The ice seems to stack near the back of the bin / drawer where it is dumped and that is what goes all over when the drawer is jarred as you open it
  • Anonymous Mar 15, 2014
    Freezer drawer of my monogram refrigerator is frozen shut because of the ice maker. What is wrong with the ice maker to cause this to happen?
  • Anonymous Mar 23, 2014
    Can not open ice maker drawer to put ice maker back on
    New Friend:
  • 129 Answers
SEE IF THE CANAL OR HOSE . WHO FILL THE ICE MAKER INSIDE ITS PROPERLY SET. COULD BE NOT PROPERLY ALIGNED OUT OF THE POSITION OR MISSING
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
Posted on Jun 29, 2008
Ice build-up on the bottom of the freezer drawer
Water on the freezer floor has only two sources, 1) ice maker overflow/leak, or 2) defrost drain plugged. For the first you can turn off the ice maker and shut off the supply water for a few days to see if the problem recurs. If this is the problem determine if the water fill valve leaks or the ice maker is the problem and replace the offender. For the second, thaw out and clear all the ice, paying special attention to the drain located under the freezer (cooling) coil. Then clear the blockage from the drain tube. BE CAREFUL AND DO NOT USE WIRE OR SHARP ITEMS as this can pierce a hole in the drain requiring replacement, not something you want to do or pay for. A turkey baster and hot water are useful tools to flush out the blockage allowing water to drain freely into the defrost drain pan under the refrigerator.
Sep 12, 2014 | Refrigerators
Ge pfs22mis ice maker won't stop
Hello:
No real fix here, just a design flaw..
Try switching ice maker on /off switch until you ready for more ice..
Cheers
Jul 15, 2017 | GE PFS22MIS
Water collecting under the freezer drawer, then freezing
We just had a similar problem with our Maytag side-by-side in the bottom of the freezer. Just as you described...sort of a glacier on the floor of the freezer that slowly melts toward the door. After several attempts to remove the ice, only to have it form again, my husband spoke with a helpful sales person in an appliance center. He said there's a drainage plug/line on the back that's supposed to funnel condensation to the evaporation tray underneath. It gets clogged and frozen. Sure enough...my husband pulled out the freezer, opened the visible line and it was all frozen and full of gunk. He had to use a hair dryer to thaw it out, then flushed it. It was amazing how much stuff came out of there. We've had no more problem since.
Apr 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice build up on floor of freezer drawer starting under ice maker
since this problem is discussed over and over on various models, I point you to a detailed manual that shows (with images) how to solve the frozen drain pipe issue. This is the manual by Avi
good luck
Feb 08, 2009 | LG LRFC25750 Refrigerator French Door
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Open Questions:
See all GE PFS22SBSSS Stainless Steel French Door Questions
GE PFS22SBSSS Stainless Steel French Door Refrigerator Logo
207 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
