Question about Dell Dimension 4600 PC Desktop
Windows xp will not turn on
I turn the pc on and it goes through the memory test and then gets to reboot from cd and turns self off.  Have tried with or without the xp cd in and also tried pushing f8 before anything comes up on screen.  I am currently working on a mac to try to find a solution.
  • samb341 Jun 29, 2008
    nothing happened just the same  with both f2 and f10
  • 148 Answers
I need you to go to your setup screen this is accomplished by either pressing the f2 key or the f10 key when the computer starts booting. Now look to see if your hard drive is listed. if it is do not make any changes just escape out and contact me for further directions I will help you walk through it ,
take care .. be mucho blessed.. Mark
Posted on Jun 29, 2008
I turn my lenovoG560on it goes to start up repair then to blue screen then shuts down what can i do
First try this, Remove ALL media, DVD, CD, USB, etc., unplug, remove battery, plug in, reboot, use the F keys to restore/recovery software. If that fails, open the machine, reseat memory mods, reseat the HDD, replace the CMOS battery. You may have to remove HDD and test amd the memory and test. OR try a repair disk for your OS. Have you done any Hardware or software upgrades/changes?
Dec 25, 2012 | Computers & Internet
Dell Inspiron 9100 running XP boots up but then won't work. Diagnostics results in the fololowing: --DST Short Stats Test-- Test Results: Faill Error Code: 1000-0142 Msg: Unit 4: Drive Self Test...
Hard drive has bad sectors. Before your replace your hard drive when getting this error, try this- Boot from a Windows XP CD and choose Repair at the first prompt to get the recovery console. Type "chkdsk c: /p/r" at the prompt. Repeat until there are no errors found. Exit and reboot. It worked for me.
Jun 14, 2011 | Dell Inspiron 9300 Notebook
Pc blue screens with 0x0000008e (0xc0000005, 0x807019uf, 0xaa7ff48c, 0x00000000) after reboot goes into safe mode boot option. Selecting xp pc boots normally. repeated reboots pc works fine. But if left...
STOP 0x0000008E errors are usually caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Download and run from a floppy or CD MEMTEST86 at
Aug 05, 2010 | Evesham Evolution PC Desktop
Laptop wont start windows xp pro. goes to a blue
Take one memory stick out and test. Then do the other. Also checking each memory slot.
If not solved. When the computer starts, continually press F8 until you get startup menu- select SAFE MODE and fix the driver or software that is in startup
Roll back to last known configuration that worked.
While you are there- disable Auto Reboot on Failure.
May 02, 2010 | Computers & Internet
I have a Dell E510 that will not boot up. It has power and I get error codes 3 and 4. I have reseated the memory and replaced the memory to new memory and tested them one by one in the first slot. The...
Ok what you might try is get a new hard drive and install windows on there and see what happens. Also if you are able to before you try a new hard drive you should do a system restore and restore it back to the day that windows was installed.
Jun 18, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Emachine W6409 will no longer turn on
Your hard drive is probably crashing or has crashed. You need to start your computer with an XP CD and try to use the repair function. You'll be able to tell if the hard drive is still working or not once you run the repair function. Let me know what happens or if you run into any problems.
Feb 20, 2009 | E-Machines W6409 (7234) PC Desktop
I want to format my Acer travelmate 2400, but when I try to reboot from the Windows XP CD, the pc just restart without rebooting. is there another way I can format my PC?
check your BIOS to load the from CD first. Also turn off the Acer logo at start if you can. look for a "Tab to see boot up"
Jan 20, 2009 | Computers & Internet
win xp is not supported by Microsoft any more and hasn't been for a number of years
That means that any blips that would normally be corrected during installation is not longer happeneing
Win 7 also is no longer being supported and there are already problems occurring in that system
many applications that have drivers in win xp no longer have the drivers so printers and other PNP units will not operate
Time to move up to win 10
Dec 17, 2017 | HP Compaq d530 Ultra Slim PC Desktop
PC keeps on restarting
Power supply can be your issue , when windows boots from CD it a mear dos-mode boot , If it was motherbaord problem it wouldn't boot at all . If you move power supply to test the motherboard issue just make sure it enough power to boot the other motherboard ( some pwer supplies can boot all motherboards )
Jul 31, 2008 | ASUS P5S800-VM Motherboard
Restoring pc to original state
u nee dto get in bios make sure cd boot order setto cd 1st ok then put xp cd in drive it say boot from cd hot yes then follow inst ok to formatt it and reinatsll xp then update it at windows online ok
Jan 28, 2008 | Microsoft Windows Xp Home Edition Sp2...
Dell Dimension 4600 PC Desktop Logo
21 people viewed this question
Alun Cox
