Related Tags:
This problem should be removed because:
Problem with JVC AV-32120 32" TV
Help- with JVC 32" CTV
Have a JVC model AV32120. Problem with secondary voltages. Doesn't switch on. Any leads would be appreciated. Changed STR6626 and 1000mfd 35V. No change. Thanx in advance
Solutions (4)
First, STR-F6626 must be OEM.
Robert
On Sat, 9 Oct 2004 11:12:19 -0300, "EGuy"
Not true at all. We fix these sets with "generic" ICs all the time. I have
compared several "originals" from JVC with the generic ones and found no
differences at all in operating parameters including temperature. You have
to be very thorough in troubleshooting these power supplies, but there is
not a problem with using generic STR-F6626 ICs from a reputable supplier.
Leonard
Like I said, you have to be thorough in troubleshooting these. It is my
experience that when the chip is not switching at all, it is likely bad,
along with the diode(s) in the primary. But then we get more lightning here
than in most areas and these ICs seem to fail with a sneeze...in cases
without surges there may be more common failure modes in these power
supplies.
Leonard
I had a similar model (UK) that wouldn't strike up, and turned out to be a
small diode in the primary circuit.
AW
JVC 32" Television jittery picture
Hello, I have a JVC AV32120. The left and right sides will slightly jitter initially with use but after a couple hours the problem...
JVC 36
I picked this TV up at no cost. It is in perfect cosmetic shape. A61 chassis. The on-off switch is broken off, just the paddle. THe fuse was...
jvc will not power up
jvc av 36980 will not turn on. Is the 926 capacitor soldered and if yes is this difficult?
jvc
my v turn off. cannot recieve signal
Add Your Solution
code for av- 32t77sk
handset will not adjust volume
model 32120 totally out, nothing happens when
model 32120 totally out, nothing happens when power button pushed; may have been zapped by lightning/power surge? is...
Continuous off on. If it's power supply how...
Continuous off on. If it's power supply how much should local shop cost to fix? (ballpark)
Fix-O-Meter
67
67 people viewed this problem
- 0 people are following this problem. Be the first!
Top JVC Standard Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
