Question about Frigidaire FRS26KF5C Side by Side Refrigerator
No crushed ice
Our Frididaire elements side-by-side has both crushed and cubed ice in the door. It will not crush ice hardly at all. It will crush a very small amount then just dispense cubed ice. Is there something we can do or check?
Thanks
  • robnhollye Jul 03, 2008
    We did what was suggested and it helped for one day then went back to doing the same thing.
    Thanks so much for the suggestion anyway,
    Holly
  • Anonymous Oct 30, 2008
    I have the same problem and tried the fix offered. It appears that there may be something broken in the mechanism that crushes the ice. Is the tray/crusher a part that is sold on the market for replacement?
  • 481 Answers
  • pull out the auger assembly (big plastic tray with a metal coil in it that holds the ice) and dump all the ice out.
  •  clean out the whole thing and let any ice residue melt, then try it.
  • sometimes a small amount of ice will buildup around the ice crusher and keep it from engaging.
Posted on Jun 29, 2008
  • Mike Durland
    Mike Durland Jul 06, 2008
    • none of my free suggestions have helped you at all?
    •  if you fell  the issue with the machine is something else let me know, i will try to help you figure it out.
    • it seems that we were on the right track if it worked for a day.
    • the icemaker might be leaking water inside the auger and freezing.
    Mike
My side b side fridgidaire will only make cube ice now not crushed
fridgidaire makes cubed ice but crushes ice. could be push button on door, mechanism that crushes ice, if not mechanically inclined please call refrigeration tech to check out.
Apr 10, 2015 | Frigidaire FRS3R5EMB Side by Side...
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
PLHS239ZCB2 Frididaire dispenses crushed ice and will not dispense ice cubes
Good Morning Mike,
I understand your Frigidaire refrigerator, model# PLHS239ZCB2, will only dispense crushed ice and not cubed ice. I suggest making sure your ice bucket is in correctly, making sure that the back of the auger is lined up correctly with the drive mechanism. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Frigidaire FRS23H7CS Side by Side...
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice dispenser only dispenses crushed ice
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Frididaire Gallery series side by side with ice and water in the door
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 14, 2007 | Frigidaire FSC23F7D Side by Side...
Frigidaire FRS26KF5C Side by Side Refrigerator Logo
361 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
