Question about Gateway Bestec ATX-300-12EB3 305w Power Supply (ATX30012EB3) Power Supply
Power supply I have a e machine it was working fine but I felt it running very hot , Yesterday the fans stopped working and my screen went blank. I tried to replace the power supply with the same Bestec ATX 300 same as what was in the computer. I think I hooked it up all right. The light came on in the front and a tiny green light on the mother board came on the fan made a half turn and then nothing. I returned this power supply and got another of the same one. And the same thing happened. Could it be my mother board or a short somewhere? I called gateway and they said must be a bad powersupply but two not working? seems odd to me, Again I am pretty sure I have it all plugged in right. And if it is my mother board and I have to send it out to get fixed. Is there any way I can put my hard drive into another computer to remove private information before I send it out? Any help would be greatly appricated!
    Problem Solver:
  • 13 Answers
Any alarms sounding? Looks like you have a RAM problem. Clean the 'teeth' of the RAM with an eraser and reinsert. When the RAM does not connect properly the machine loses its ability to 'think' so it does not start. The light on the MB and the fan spin says that the power supply is OK.
Posted on Oct 29, 2012
  • 36 Answers
Angeldram3
as i think ur processor over heated. or processor can dos not work fine or heat sink not installed properly. remove heat sink, and use heat sink component (a whithe colour gel. u can buy it any computer accessories shop) use it top of ur processor then attached heat sink. and connect processor fan. before installing heat sink check processor fan. then cleare CMOS by removeing battery (because this problem also can happen wrong frequency setting in CMOS setting).
Posted on Jun 29, 2008
  • Buddhadev Chowdhury Jun 29, 2008
    angeldram3
    sorry a spelling mistake in my solution in first line "processor can dos not work fine"
    correct line is "processor fan dos not work fine"
    Buddhadev
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
My Akira Pedestal Fan stopped working suddenly
the major problem with fans is the bronze bushes that the armature runs in get dry from use and seize on the shaft. IF you are capable get to the bushes and you may find a piece of felt next to the bushes . Put some machine oil into the felt and spin the fan with your finger until it loosens up. Otherwise scrap it
Dec 08, 2013 | Cars & Trucks
I have a Bunn Ultra 2 machine it was working fine last week I left it running and when I went and looked at it yesterday it had shut off and would not start up. I unplugged it from the outlet and it...
was it hot? the compressor may be overheated and went into shutdown until it cools. it's safety feature if the fan stops or if the airflow is blocked by too much dust. clean the filter, check the fan, and try again. if it's not hot, it's the transformer that powers the main circuit board.
Apr 14, 2013 | Bunn Margarita Machine Ultra 2 Slush...
The screen went blank when I was using the laptop and know it won
You are experiencing power supply failure. The main board may not get the right power to boot up the devices. You need to refer your product to a qualified servicemen. Problem can be solved online.
Thanks. Cheers!
Apr 21, 2010 | HP Compaq nc6000 Notebook
I have a 13 month old Acer Aspire ax1700 Desktop. Had turned it on yesterday and Fan was making lout noise. Today I turned it on to check it. Was on for about 10 minutes and it just turned off. There are 2...
It seems that the power supply unit has gone. If you power it on and nothing happens then obviously the psu has gone. The heat that you felt was the psu overheating because of no fan and hence no ventilation. The noise was of the faulty psu fan that got stuck or did not work and the psu got overheated and got burnt eventually. Please replace it with a new one as a repaired psu may work but you cant rely on it.
Mar 22, 2010 | Acer Aspire AX1700-U3793A PC Desktop
Brother intellifax 770 No Power? LCD is blank
I have the same problem: no LCD. Determined that the outlet was fine, but the machine did not respond when unplugging/plugging it in. Support said I needed to take it in for repair. Unplugged it, unscrewed the bottom plate, and found a blown fuse on the circuit board connected to the power cord (needed to gently lift it from its cradle).
Jan 09, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Westinghouse 32 inch screen goes blank
Westinghouse LTV-32w1
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Dec 25, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Scott HDTV model LCT37SHA
We have just been working on this exact problem and have a page with all the details -
http://www.findonefindall.com/toyota-sienna/LCT37SHA_Scott_Akai_LG_LCD_TV.htm
Hope it helps!
Oct 26, 2008 | Akai LCT3201AD 32 in. LCD Television
Gateway Bestec ATX-300-12EB3 305w Power Supply (ATX30012EB3) Power Supply Logo
187 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
