Question about Microsoft LifeCam VX-6000 Webcam
Hi can u help me cam doesn't work
It doesn't work at all, maybe something is wrong with the wire beause when i try to connect it, it says not connected plus nothing happpens I am really sad, :( i don't know what to do with it throw it :( orkeep it and or someone can fix it?
  • Joshua Murchison
    Joshua Murchison May 11, 2010
    Did you install the cd first? Have you got it working again?
    President:
  • 8,637 Answers
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 14, 2009
Kenmore 790
I could be wrong, but from your limited description I am assuming that you cut the cord and wired direct to the box. You may not have 240 volts at the box and are trying to connect it to 120 volts. A dark green wire is the safety ground. The white is neutral and two colored wires are supply lines with 120 volts ( average) EACH. Better get someone in there that knows electricity and how to make proper connections to the proper voltage. Otherwise you are asking for major trouble.
Jun 26, 2013 | Ovens
1994 chevrolet 1500 pu 350 replacing battery cables positive large cable to starter does the pigtail connect to alternator have another small wire that was connected to battery before coming from fire...
The cable should be to the starter and alternator. The other wire maybe an add on, some one put in it. I would leave it off and see if something doesn't work in the cab
Sep 05, 2011 | Chevrolet 1500 Cars & Trucks
I have intex IT-305WC web cam. i am using it on my desktop. XP -SP3. as i attach the cam into my USB port. my pc is not able to detect it. earlier it was functioning properly. what to do now? i have tried...
hi! it may aslo the problem with the memory card or wrong file layout.so you should recheck it again. maybe there is something wrong with your camera parts.
www.skiliwah.com
http://www.digitalcamera-parts.net/
MSN:e-8090team@hotmail.com
Aug 17, 2011 | Cameras
I just installed a Wood 59018 timer, and when i try to turn it on manually, I hear the relay click on and then immediately off (the attached light turns on and off too). That's when the switch is set...
Timer is wired wrong and timer white and timer red wires are probably connected together.
Timer white wire has to be connected to white neutral wires that are twisted together and shoved to back of box. This will power the clock mechanism inside timer.
If box does not have white neutrals, then connect timer white wire to bare ground wire along with timer green wire.
Timer black wire connects to Hot wire.
Timer red wire connects to Load wire.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Jul 09, 2011 | Woods InWall 7 Day Digital Programmable...
The fridge has lost power
hi here,
something might be wrong with the wiring that connects the power wire to the fridge. better have someone professional take a look at it as it's a delicate solution. Better yet, try plugging the fridge somewhere else, maybe your current plugging socket has problems.
May 18, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
My web cam is not working
maybe there is something wrong with the connection you can check th connect or look world of warcraft gold for sale and cheap wow gold
Dec 05, 2009 | Dell Inspiron 1545 Notebook
Hi, I have a problem with my Hyundai tiburon 2003 2.0l standard The Fuse SNSR Allways short when i try to start the car or just when i put the key at on, I try to disconnect the four sensor,the 2...
The fuse is blowing,most likely because of something else in the same circuit,find out what else is not working on the car,what all is not working.Is the car not starting?
Nov 16, 2009 | 2003 Hyundai Tiburon
W705 mobile phone fault
just try to update it's service by downloading a new software version i guess.. maybe i could help..
May 26, 2009 | Sony Ericsson Walkman W705 Cell Phone
Idle problem
Did you turn clockwise the idle cable when you first installed the frame?Try to turn it counterclockwise.
Apr 11, 2009 | 2004 Honda CBR 1000 RR Fireblade
Doesn´t work anymore
Hi. Forgive me for asking, but did you try unplugging everything, including the firewire, and plugging it in again?
If you try this and it doesn't work, try shutting your laptop down gracefully, then unplug all the Firebox connectors including the electricity. Wait about 10 seconds, then reboot your laptop. Don't open your recording software yet.
Connect the electricity and the firewire as described in the Firebox manual, and then open your recording software. If this doesn't work, something might be wrong with the Firebox.
The problem you have happens once in a while with mine--it seems to be connected with overheating or something. Anyone else have this problem?
Oct 01, 2008 | PreSonus Firebox 6x10 External Sound...
Microsoft LifeCam VX-6000 Webcam Logo
20 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
