Question about Toshiba 62HMX84 62" Rear Projection HDTV
HDTV cables Tv does not reconize any HDTV cables. I tried it with the cable box, computer, and DVD player. It will only operate with the 3 component cables.
    New Friend:
  • 129 Answers
Pressing INPUT on the remote control
displays the current signal source
(press INPUT again or 0–8 to change and be sure is on hdmi 1 or 2 if not let me know , to reset to the factory default settings
your raring to my answer highly apreciate
thanks
Posted on Jun 29, 2008
I have a 70" element TV bought used no remote how do I get the DVD player to work? What channel ??? tv av component etc.....
How do I hook up my tv,dvd player,vcr, and cable box?
askville.amazon.com > Entertainment > Television
Dec 3, 2009 - Recent Questions About: hook tv dvd player vcr cable box · Entertainment > ... Exclusive Coupons To Get 30% Off ... Check the back of your TV to see which type of hookups are available and use the appropriate cables.
Element 46" Class LCD 1080p 60Hz HDTV, ELDFW464 ...
www.walmart.com/ip/Element-46-Class-LCD.../17188433
Walmart
Rating: 4 - ‎190 votes
The Element 46" 1080p HDTV features a brilliant full-HD picture for your viewing ...ShippingPass. H&R Block Tax Software 15, Deluxe + State. $34.70 .... I really cant stand having to use another remote...thats the point of having a .... Just a regular DVD player and it works perfectly fine with the TV. ..... Get to Know Us.
5 Easy Ways to Hook Up a DVD Player (with Pictures)
Jan 10, 2016 | Televison & Video
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
How do i put it to play dvd player
  • Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
  • 2
    Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
  • Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
  • 4
    Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
  • 5
    Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
    Car Tuning
  • May 24, 2012 | Initial HDTV-320 32 in. LCD TV
    Need to attach dvd/vcr player to cable box and hdtv
    DVD/VCR will take inputs of either component BGR RW or composite YWR and will provide either composite or HDMI output. My suggestion is to take the "best output" from the cable box you can and use the HDMI output to your HDTV. This will take the best your cable will offer and give your TV the best signal to use.
    Cable box ------ to DVD/VCR ------ to HDTV.
    Sep 04, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
    Ihave a bose 321gsx, I want to hook up my hdtv . ,blue ray dvd and vcr. Brain is frozen right now. Could use some help.
    How to Connect an HDTV to a DVD Player
    Hooking up a DVD player to an HDTV, or high-definition TV, is just as simple as hooking one up to a standard-definition TV. While a regular DVD player may be hooked up to an HDTV, it does not necessarily mean it will have high-definition quality picture. Unless a Blu-Ray player is connected to the HDTV, only a standard-definition picture will be shown.
    Things You'll Need:
    * Component cables
    Instructions
    Do not purchase HDTV component cables to hook up a regular DVD player to an HDTV set. Unless using a Blu-Ray player, only standard component cables are required. HDTV sets consume a lot of energy and should be plugged directly into an electrical outlet rather than a power strip.
    Turn off all electronics before connecting and disconnecting wires to reduce the chances of getting an electrical shock.
    Ensure that you have the proper cables to hook up your new HDTV. Take inventory to see if you have an ANT-IN, DVI-D/HDCP IN, Video In or Component Video In cables. The placement of these plugs will be indicated in your user book.
    Begin by connecting the coaxial cable to the back of your cable box. Run a video cable to the TV; an S-Video cable may be used as well if you do not have any other video cables.
    Locate a digital audio cable, or analog audio cable. Connect the audio cable to the TV from the cable box.
    Now connect all other components including DVDs, VCRs or LaserDISC players. Try using all digital audio and digital video connections for the most complete HDTV experience.
    Use a splitter to connect multiple components such as cable box to DVD or TV to VCR to avoid running out of chords. Calibrate your HDTV before enjoying fully, adjust the brightness, contrast and color settings.
    Tips & Warnings
    You can utilize a program to help with proper calibration of your HDTV system; these instructional videos can be purchased from many electronic stores.
    You can opt for the store from which you purchased your HDTV to hook up the system for you. They will often calibrate the system for you as well.
    Hope it helped.
    Have a nice day...
    Feb 26, 2011 | Bose 3 2 1 GSX System
    Connect dvd recorder to cable box and hdtv
    I have posted a tip that should help you out with your problem follow the link below but there is one minor variation for connecting to your TV.
    On step 3 of the connections section substitute the follow for your situation.
    You will need 1 component cable (Red/Blue/Green/Red/White cable)
    3) Connect the Green/Blue/Red connectors to the back of the DVR labeled "COMPONENT OUT" matching the colors. Connect the same ends to the input of the back of the TV again matching the colors.
    4) Connect the last two connectors (Red/White) to the back of the DVR to the AUDIO IN on the TV.
    Other than this variation all shoud be the same.
    CLICK HERE for complete tip.
    Good Luck...
    Jan 27, 2010 | Panasonic DMR-E55 DVD Recorder
    Can't hook up DVD player
    I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
    Jan 12, 2008 | Protron PD-007 DVD Player
    Picture, No Sound from HDTV Box
    CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
    Apr 20, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
    "No Signal" when DVD player is hooked up via component video
    If you are using the same cables,same input and the cable box works ok. I would look into the settings of the DVD player. Such as is it a progressive playback and is progressive turned on. It is not turned on by default because not all TV's could handle progressive in.
    Feb 07, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
    Toshiba 62HMX84 62" Rear Projection HDTV Logo
    35 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
