Question about Brother Office Equipment & Supplies
I have a brother mcf-8840d with an error code 71. Any thought on what to do?
    Genius:
  • 3,422 Answers
The error code 71 means to unplug and call brother. try unpluging all the cords from back for 30min and see if this fixes the problem.
Posted on Jun 29, 2008
  • 758 Answers
It's not good. Every laser printer has a spinning mirror to spread the sharp laser beam into a line that scans across the page. Your Error 71 means that the mirror motor can't synchronize with the brains of the printer. The problem is most like the motor bearings, meaning you need an new Laser Scanning Unit (LSU), or it could be the main board acting up. Either is pricey.
I hope that helps
Please rate accordingly
Thank you
Computerrep
  • Jean Sintulaire Jun 29, 2008
    How long have you had this printer?
    Genius:
  • 1,847 Answers
  • Legin Varghese
    Legin Varghese Jun 29, 2008
    Error Code(Hex) : 71
    Symptom: Scanner motor does not synchronize with the reference clock.
    Probable Caus:- Laser unit defective- Main PCB defective
    Solution:- Replace the laser unit- Replace the main PCB
  • Legin Varghese
    Thanks for choosing Fixya.
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
GETTING MACHINE ERROR ERROR 78 , PRINTER NAME BROTHER MFC 8840D
Machine Error 78 indicates a mechanical malfunction of the Brother MFC-8840D. 78 represents the error number. You have to contact Brother Customer Service 1-877-BROTHER.
Dec 22, 2010 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Machine error 6D
I looked that error "6D" and could not find anything.
Although there is a error 6E that denotes a hardware problem with the machine.
Mar 12, 2010 | Brother MFC-8840D All-In-One Laser Printer
Machine error 71
This error means that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial stage of the maintenance mode.
If the error comes back call Brother support, here are the contact details:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
Phone: 1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
Monday-Friday, 9:00am to 8:00pm Eastern Time
Oct 27, 2009 | Brother MFC-8840D All-In-One Laser Printer
Brother 4100 fax error code # 71
Error 71 is a laser scanner error.
Inkworks
866-381-0541
Nov 19, 2008 | Brother IntelliFAX 4100 Laser Fax
76 error on brother 8840d
the error code should reset after replacment. If it did not you may have a bad fuser or all connectors to the fuser are not connected or are bad or you may have a bad logic or power pcb.
Hope that helps...
Jun 17, 2008 | Brother MFC-8840D All-In-One Laser Printer
Machine error 71
Error code 71 -- ( Polygon motor does not synchronize with the reference clock. ) What ever that means - hope that helps.
Mar 20, 2008 | Brother MFC 9700 All-In-One Laser Printer
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Error Msg: PAPER JAM in Brother MFC-8840D
one of the jam switchs is stuck down or paper concertina in fuser assy
Dec 28, 2007 | Brother MFC-8840D All-In-One Laser Printer
358 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
