Question about Sewing Machines
Sewing machine problems
I have a model 16951sewing machine, to sew foward you have to holdthe reverse lever down, and the stich pattern doesnot change either?
Having the exact same problem, oiled the machine, but I still can't change stitches...any advice?
Posted on Dec 02, 2010
Buttonhole pattern Wheh I select the buttonhole pattern that I would like I get an error. The machine sews on every stitch but the buttonhole pattern.
Are you using the buttonhole foot when you try? It will look like this.
Also, there is a lever you need to pull down to deploy when stitching buttonholes. It triggers the machine to stop stitching out the side of the buttonhole, reverses then does the other side. Its a little lever up in the head near the pressure foot bar and needle bar. It will touch the sticking out finger on the buttonhole foot to trigger the reverse motion in the programm.
Oct 25, 2011 | Singer CE-200 Quantum Futura Computerized...
My sewing machine juki is not running. The stiches is too tiny and unless you pull the material it won't run . Do you havethe idea why and how can I solve it?I was using it before and all of a suddent it...
I would go to there web site and Down load the manual to the model you have. You should find what you need to know about setting patterns in it.
Feb 22, 2011 | Juki Sewing Machines
My machine won't stitch foward only backwards the model is385.15516000 I tried to oil the bobbin area and the spring that causes the reverse swithch to happen.
Wipe away as much of the oil as you can.
Only oil a sewing machine as indicted in the manual for the machine.
When a lever/gear is stuck, try warming the area with a hair dryer. This will loosen old lubricant.
If the problem continues, the machine needs to be seen by a professional sewing machine service tech.
Mar 03, 2010 | Kenmore Sewing Machines
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
Will not feed material or sew
Google the item name and model and see if they have a website with a store locator or repair center.
May 23, 2009 | Euro-Pro Sewing Machines
Machine will not sew forward without backstitching
You have selected the Stretch Stich (SS) mode on the stitch length regulator, just turn the knob around until you have a number 1 - 5 and that should be it.
The model number will be the last digits on the metal compliance plate with voltage etc.....looks like:
V / 1234 / 123454321 / 2016
www.bargainbox.com.au
This then would be a Model 2016
Nov 25, 2008 | Sewing Machines
Reverse Switch Control on my Kenmore Sewing Machine
My back swith button is not working on my Kenmore sewng Mchine. Can you tell me what the problem is?
Aug 25, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
41 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
