Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Bright On left and right edges
We have just had our Philips 55PP8620 tv fixed( had like 3d bubble around images) and have got it back and the left and right edges of the screen seem very bright as does any part of the screen when there is a white image. we have tried aligning the multipoint and converge arrows but they also don't seem to save. what is the intellisense meant to do. We got this tele for free as the owner thought the previous problem was going to be to tedious to fix. so we only have 1 manual and it is in every language but english. is there a site where we can get a free manual please help as we are totally clueless!
    Champion:
  • 230 Answers
OK, Time to fix it !!. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms.SOme time SSB is defective ( small signal board, replaced it ) If you have questions? noetvs@embarqmail.com . Good Luck !!
Posted on Jul 24, 2008
Backlight went out on my 42in phillips lcd tv
You can verify it's the back light.
Turn the set on and place a bright flashlight against the screen. Look around the edge of the flashlight for moving images. This will show the back light is off.
You most likely need a back light inverter board.
If this set is under warranty you should return it to get it repaired/replaced by the seller.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(replacing board ) or have a friend with knowledge/skill you can fix it.
Since you did not give a model I can not give more direct information. You can search for a board at; eBay, shopjimmy.com, and many other sites.
Mar 03, 2011 | Philips Televison & Video
32ta1600 tv does not have any picture or Display, Cannot even see Menu on TV only sound. How to rectify?
This looks like a problem with the back-light inverter.
Since you can hear sound you can place a bright flashlight against the screen. Look for a moving image around the edge. This verifies the picture is being processed.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(board replacement) or have a friend with knowledge/skill you can fix it.
You will have to get a replacement board for your set.
Remove the old board from the back of set.
Install the new board.
That should solve the problem.
Mar 01, 2011 | Philips Televison & Video
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
Philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
Oct 22, 2009 | Televison & Video
My TV looks like if i was watghing a 3D Movie.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2009 | Philips 55PP9401 55" Rear Projection...
My Philips 51PW9363 has pink and green colors only!!!!
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 05, 2009 | Philips 51PP9200D Television
Philips tv top corners and bottom going 3d
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Oct 24, 2008 | Philips 60PP9202 60" Rear Projection...
Colour misalignment and focus
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
PHILIPS 55PP8620
Good Day;
It sounds like the CRT COOLANT needs replacement, it is a fluid that trys too keep the picture tubes cool , but it some times get "dirty". The fluid is called 'PROJECTION TV COOLANT', it contains; High Concentration of Ethylene Glycol. You can purchase at M.A.T. Electronics; (215) 354-7667, in PA. Part Number 212072-16.
BUY at least 2 containers. CAUTION: remove tubes from TV, just alot of plugs,remove plugs, clean "fluid" chamber, replced discarted fluid. Good Luck, big IRISH. PS more INFO; come back.
Mar 28, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
