Question about Sansui DTV2760 27" TV
Parental controls Can't watch any DVD's on this Sansui TDC2075A DVD/VCR? /Tv Combo, Can'tturn off the parental lock in the DVD side of the menu. SAhows Parenatal lock is on and set to 5. When Hit the Parental control OPtion bbutton asks for password. Tried thed Holding the VOl - ON both remote and TV same time # secs And even Longer several times, but still Can't turn off the parental control, got the tv side of th V CHIP turned off, but that's it! Dale
    Genius:
  • 2,035 Answers
Please unplug the tv for 30 minutes replug it back and check it still parental control is on if its you need to contact the tv company .........
Posted on Jun 29, 2008
  • 161 Answers
Dale there's should be specific instructions on how to turn off the parental lock on the owner's manual your Sansui came with. Read it thoroughly, perhaps the solution can be found in the troubleshooting section. It can't play DVDs? There are two formats of DVDs, some being double layered (also known as DVD-9) and the single layered (DVD-5+) Some players can't read some of the later formats. It could also be possible that the players parental control is disabling the DVD function. Just check out your manual Dale. Let me know how it goes.
  • 983 Answers
Try giving the reset ...........
Zenith XBR716 DVD Recorder / VCR Combo parental bypass
I don't know if this will work but try entering four 0 (zeros) first. If it doesn't work enter as many 0 (zeros) that you can and see if that works. Hope this helps :)
Apr 20, 2014 | Zenith XBR716 DVD Recorder / VCR Combo
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Have Sansui @0" tv/dvd/vcr combo that my son locked the parentals control
yes..but you'll need to have a service professional do a firmware reset on this unless you can gain access through the service and support menu..
is this a new form of Child Protection and control?
Mar 20, 2008 | Sansui DTV2760 27" TV
How do you unlock patental controls on my tv
You should be able to find parental controls in the main dvd on screen menu
Aug 05, 2009 | Televison & Video
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
PLEASE HELP, PARENTAL LOCK CODE ESA DVD/VCR COMBO UNIT
this is a new thing on dvds. must reset.
Feb 25, 2008 | Televison & Video
DVD parental lock
I have a GE 13TVR62 (with a problem listed here). I've learned that the Parental Lock Settings are changed by using the Remote Control. Usually the actual Settings are changed by pressing the Up or Down or Left or Right Arrows to make the Change; while the Parental Lock is Highlighted on the Menu.
Dec 22, 2007 | GE 13V110TD 13 in. TV/DVD Combo
Parental control feature
if you can get to the operations menu page, after selecting on or off next to parental lock, press stop button four times then press enter this should clear the security code. press the number keys to create a new code press enter.
Dec 08, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sansui DTV2760 27" TV Logo
310 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
