Bad Power Supply inside the computer. Weak voltage power rail. For more information I need the computer manufacturer name, and Model Number. (Back of a desktop computer tower next to the Windows product key, or up on the side of the computer tower)Bad Power Supply inside the computer. Weak voltage power rail. For more information I need the computer manufacturer name, and Model Number. (Back of a desktop computer tower next to the Windows product key, or up on the side of the computer tower)
HP laptops are well known for motherboard issues, and will usually involve a replacement board, at this point have it checked before a decision is made.
Topside control is in "Locked" mode. If you accidentally locked your control
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
or
One of the buttons might be stuck in the down position
If these do not help let us know your control make and model & we'll see what we can do to find out more for you.
Quick and dirty here we go, before you click finish see if the hard drive light is on, if it is is it on steady or is it flashing. Doesn't matter so long as it is on, go have coffee for 30 minutes or so and then come back.
Check to see if the hard drive light is still flashing if it isn't then do this press ctrl+alt+del this will bring up an screen. On windows 7 you want to click on task manager then open the applications windows, look and see if there is anything there that says not responding. If not click the finish button and let it run for awhile.
Thing you have to realize about this system of installing is that everything is compressed and needs to be unpacked and this can take awhile to do this, also make sure that network cable and phone cable are disconnected from the computer.
If your start button is flashing even when you hit your start button . Your electronic touch control board (ETC) is not working correctly . Either the intergrated curcuit board is not responding or the actuator on touch panel is broken . Push start button in and see if the button makes a clicking noise. If it does replace curcuit board , if it does't replace the part where you touch.
The rollers of the printer must have accumulated dust such as sand or something. Try cleaning with alcohol the parts which moves in time of printing. The curcuit may also be damaged. Thanx.
You have the phone line plugged into the wrong jack on the machine. The line from the wall should plug into the jack labeled "L". The other jack is for a telephone or answering machine.
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes. help! trinitron kv29f1u only clicks and blinks
do you see anything when you press the on button? if not, it might be the motherboard, which means the most important part of the computer is broken and it has to be replaced (the motherboard that is, but i warn you, OEM versions of windows might not work anymore) if you see something until windows should start just replace the harddrive
Post in a Comment
