Question about Ricoh Aficio 1035 Copier
Help me ! Ricoh aficio 1060
Sir, what should we do if our machine (Aficio 1060) has a problem? It says SC550. Thanks !
  • mmamb Sep 25, 2008
    Sir i have same prob code 550 what shuld i do pls help me i shell be very thakn full to U.
  • 42 Answers
Replace fuser web.
Posted on Jun 29, 2008
    New Friend:
Sc222, ricoh aficio 1060
Posted on Apr 07, 2014
Sc550
That service code SC550 normaly is a fuser web end error, you must replace the web and reset the % in 1.902 to "0". But i dont think the Ricoh aficio 450 have a fuser web. does this SC550 coming from your Aficio 450?
Sep 18, 2011 | Ricoh Aficio 450 Copier
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
What needs to be fixed or replaced when i keep getting the error code Sc690 on my Ricoh Aficio 1060
Hello sir; It need to replace IPU board the item no.# B0655144, we can get it for you, if you need , you may contact me at 973-533-6778.
Sep 30, 2009 | Ricoh Office Equipment & Supplies
How do I put a new supply of staples into Richo Aficio 1060
Please refer to your manual on how to install your new power supply. To ensure that your device will not damage or destroyed.
thanks
Jul 31, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Erro SC550 Aficio 1060
• Web end (requires replacement)
• Web end sensor defective
Note: After replacing the web with a new
one, reset SP1902 turn the value to 0%
Jul 09, 2009 | Quasar SP-3235 32" TV
While I am running richo aficio 1085 Pcl, It stops and show the code sc550. I try to switch the machine turn on and turn off alot of time but the result is the same, How can I do to remove this problem?
Oil Supply/Cleaning Web End. Change this and
Press the following keys in sequence.
Total Clear key 1 0 7 and clear stop for more of 3 second to enter to service program mode, eter to 1902 - 1... and change the value to 0%.
shut down the machine and turn on.
Jun 30, 2009 | Ricoh Aficio 1085 Laser Printer
Multifunction machine doesn't work
I think you mean "SC550"....all codes are 3 digits. If this is correct, it mean that the Fuser web has expired, and needs replacement, then and only then can the code be reset in service Mode. Call a tech.
Mar 12, 2009 | Ricoh Aficio MP1600SPF Copier
Error code sc550
Ricoh jp 5500 Copier Error code sc550
Sep 18, 2008 | Ricoh Aficio 450 Copier
Aficio 1060 - SC550
• Web end (requires replacement) fusing unit
one, reset SP1902 001 to 0 to
release SC550.
Jun 28, 2008 | Quasar SP-3235 32" TV
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1035 Copier Logo
1,072 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
