EVERYTHING IN MY COMPUTER IS BIG AND I TRY TO GO TO THE MONITOR BUT IT DON'T WORK. WHAT CAN I DO TO FIX THIS PROBLEM?
    Novelist:
  • 148 Answers
You need to set the monitor in your settings.here is the procedure:
1. go to control panel, then go to display.
2. click on settings.
3.where it says resolution slide the pointer till it increases in size.
4. Bear in mind the larger the size from 800x to 1024 will decrease the size of your icons and picture
5. If you can change the rate to 32 bit ty to. this may not be possible with some video cards.
If you need further assistance feel free to contact me.. Be mucho blessed..Mark
Posted on Jun 29, 2008
When i turn on the computer, the fan keeps spinning and making noise and the monitor is black screen. i tried many ways to resolve it but unsuccessful.
If your monitor is black but everything is still spinning, first off if you have opened up your PC check for certain if everything is connected again properly (especially the 4 pin connector near the CPU) and also the cable to the monitor and the monitor's power cable of course.
First of all try to connect your monitor to another device and see if it works. If it does not then your monitor is broken. if it does, let's go to the next step.
If everything is connected properly inside the PC, the odds are very high that your CPU and/or motherboard are broken. If possible try replacing the CPU and motherboard with another one if you have one lying around. If you don't you can either buy a new CPU or motherboard or if you want to take the more simple way, which is actually more recommended, go to your local PC shop and have your PC fixed.
Jul 24, 2011 | HP Compaq Presario SR2030NX PC Desktop
When I turn off the computer or restart the computer or put it in a sleep mode, my LCD monitor LG Flatron W2234S always turns black but the LED stays blue instead of yellow and the monitor does not react...
Try changing the Resolution for the lowest one, if it works it will see the letters and everything very big. I have same trouble, specially since I change the original Vista Starter for the new Windows 7, I have not found a free controler that helps me and I have seen many people with same the problem. Sorry for my english.
Dec 11, 2010 | LG 22" FLATRON LCD Monitor
I just purchased a new cpu and plugged in my Acer X203H monitor that i have only had for around 3 months and when I turn on the computer and monitor, the monitor power light flashes orange and blue and has...
Sounds like your PC is diplaying out of your monitors range. Try pressing f8 while booting up to get safe mode. then turn down the video resolution to display what your monitor can handle. Good Luck.
Nov 20, 2009 | Acer X203H bd Monitor
All of a sudden the screen got so big the text
UNINSTALL THE DISPLAY DRIVER FROM DEVICE MANAGER AND THEN RESTART THE SYS. AND IT SHOULD WORK AND IF NOT THEN YOUR VIDEO CARD INSIDE THE SYS. MIGHT HAVE GONE BAD.
LET ME NOW WHAT HAPPEN SO THAT I CAN PROVIDE YOU WITH TEMPERORARY SOLUTION
Nov 03, 2009 | ViewSonic E70f 17" CRT Monitor
When i turn on my computer everything is so big and the colours are wierd and half the screen is cut off because it is so big,
on desktop, right click on screen, click properties, settings, and increase resolution size. if it cant be solved by that, maybe you have a problem with your graphic card. try reinstalling it.
Jul 07, 2009 | HP w2207 Monitor
Can't switch on monitor screen
You must go into the BIOS of you computer and turn off the sleep mode and also in windows. Disconnect the monitor and power it on without hooking it up to the computer. If the monitor turn on and is working , then hook it up to the computer and try with with the sleep controls off to see if it works correctly.If this works you must check the owners manuals of the motherboard and monitor for the correct operation of the sleep mode functions.Then reinstall the sleep mode operation and see if everything works correctly. If the monitor fails to work. Try the monitor on another computer and see if it will function. If all this fails to get the monitor working , then you will need to have the monitor tested in a service center to find the problem and have it repaired. You should also check your computer on another monitor just to maker sure you don not have a problem with the computer too. Hope this helps you with your problem.
May 12, 2009 | Mag Innovision LT776s 17" LCD Monitor
UltraSharp 19' Screen will not autoadjust.
Start in SAFE mode (press F8 wile booting) and choose Last Known Good to see if it works in Windows DEFAULT setting.
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Goto www.support.dell.com and DL the correct drivers again
Good Luck!
Let me know what you discover ;-)
Let me know if this fixes it
Mar 26, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
HP LCD monitor power button repeatedly blinking blue.
Alright let me be the first, let's check the simple things first. Did you try toggling the FN+F5 or FN+F6....if it is playing on the other monitor you already did that or it was toggled for dual monitor and that's why you're not getting any video.
Jan 12, 2009 | R.A.M. Computers IX PACIUP4240 15'' LCD TV...
Acer P221W 20in blacking out
check your graphics card wait 20 minutes or more see what comes up i recently had that or if u try everything eg replacing everything and it still don t work try rebooting the computer with the recovery disc which means it will wipe out everything programs everything.
Sep 28, 2008 | Acer Professional P211 21" CRT Monitor
Monitor turning on and off
try to get a second monitor that you know works and plug it into the computer. This will tell you if it is the monitor or the connection to the computer. If everything appears ok with the new monitor then you have to get a new one which is probably the case
Sorry for the news. Next time there is a big thunderstorm unplug everything and make sure that your computer is plugged into a surge protector at all times. This will save a lot of money and headaches
Jul 05, 2008 | HP Pavilion MX75 17" CRT Monitor
Computers & Internet Logo
23 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
