Question about Kirby G5 Bagged Upright Vacuum
N AND D came off
My wife was vacuuming and told me the N and D pedal came off... i'll put it back in but it doesn't stay...i took it apart and noticed a metal piece in the shape of a "T" with a moveable part was floating around... what do i need to do... thanks
  • Anonymous Jul 12, 2008
    N & D came off
  • 3 Answers
The N and D are Neutral and Drive. Its for the self propelled feature on the vacuum. The transmission might be out. If you need the self propelled feature, then you need to get that fixed
Posted on Jul 04, 2008
I have a new Bissell Powerglide 1305 vacuum. It is red. I took the thing apart screw by screw to clean it inside out after my son decided to vacuum out the fireplace ash. However, once I put it back...
Knowing a little of how mechanical things are designed I would guess that when you took it apart you didn't notice exactly how the mechanism was set up that triggers the reclining feature. I would take it apart again. Then canalize how the reclining mechanism should work. It's probably to pieces that are not fastened together but are only held by positioning on assembly.
Feb 10, 2015 | Bissell Vacuums
Indicator light comes on but sweeper doesn't run.
it sounds like the motor is dead. The Light and the motor are wired differently so it is quite possible that the motor is dead and the light still works.
Jun 06, 2012 | Kirby Heritage II Vacuum
Steam not coming out
I just took my wifes S3101 apart and found both inlet and outlet hoses clear, but nothing coming out of the boiler. I took the water side of the heater apart and found the outlet nipple clogged with dirt and sand. I'm from VA Beach and my wife uses tap water. After cleaning out the water side of the heater I had to drill out the outlet nipple, it was that plugged. Anyway, after that, I reassembled and it works fine. By the way, removing the casing screws was a lot of fun (not).
Nov 30, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Replace wheel axle on my kirby g3 vacuum. have a
The spring goes inside that pedal that you step on to advance the height. Place that spring in that pedal and then place the pedal into its' groove, then put the axile and wheel assembly over the pedal and put your screws back into the mounting sections.
Dec 31, 2009 | Kirby Vacuums
I take apart and clean my DC17 every 2 weeks. When I put it back together it always works perfect. This last time, I noticed that the self propel is not working...am I missing something? I took it apart to...
The roller is not spinning do to motor or belt not working. If it is the motor then the machine will have to go back to dyson if it is the belt then that is an easy replacement.
Nov 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kirby G5 Bagged Upright Vacuum Logo
76 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
