Question about Kirby Vacuums
Put on belt - Kirby Vacuums
  • 1,673 Answers
Take the nozzle of, remove the brush roll, put the new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Posted on Jun 29, 2008
I have a powerclean bissell vaccum and i just got a belt to replace, is pulley the little metal part on the side where belt goes because when i put the belt over the metal part and around rotating brush...
You did not put the belt on its proper place that's why it happen. Replace again the belt and put it not over the metal part. Put a mark where the belt belong so that you'll remember it when you gonna instal the belt. A mark like pen or masking tape will do.
Thanks for asking.
Jul 13, 2011 | Bissell Vacuums
How to install broken belt
Why would you want to put in a broken belt?
Turn the machine upside down. There are two clamps that hold the sole plate on, un click then. This will reveal the 'belt alley' where the belt runs from the motor to the roller. Lift the roller out of the slots. Take this time to clean all the hair and threads off the roller.
Put the new belt over the wooden pulley on the roller and put it almost back in. Put the other end of the belt over the motor shaft. Stretch the belt by returning the roller to its slot. Put the sole plate back on - snap the clips - Presto.
Thanks for your question today.
Feb 03, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
How to put the belt on the deit devil breeze
Here is a detailed discription on how to change your belt. Turn the machine compleatly upside down and place head on a flat surface. There are 4 screws to take out, then remove the base plate. Near the back of the channel the belt rides in you will see a stright silver shaft. Place the new belt over that shaft. The put the brush roller through the belt, so the belt is in the notched out section of the brush roller. Grab both ends of the brush roller and pull till the brush roller is back in it's origial spot on the base of the vacuum. Turn the brush roller 3 compleat turns backwards, then do the same forward to seat the belt. Put back on the base plate and put back the 4 screws. You are now ready to vacuum.
Apr 09, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
How to put a Kirby Vacuum belt back on New belt seems too short
To put on a kirby belt all you need to do is put on the belt on the brushroll, put the brushroll into the housing making sure the marks on the end of the brushroll are the same. Take the spin dial in the front and "hook" the belt till the dial reads off. Put the head back on the machine and spin the dial to "on".
Jan 27, 2010 | Kirby G5 Bagged Upright Vacuum
Slipping belt onto motor shaft pulley
On most vacuums, you:
put the belt on the motor,
slip the beater bar thru the belt,
put the end opposite the belt into the frame,
stretch the belt and put the belt end of the beater bar into the frame.
Hope that helps!
Apr 25, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
make sure the belt is in the middle before u put the head onto the vax front. turn the nozzle to red to hook the belt on . should be easy if the belt is int he middle space and up not down.. the the hook should hook onto the belt quite easily.. put the head onto the vax front and turn to green for go. the green light should be on if u put the belt on correctly .
Sep 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Hoover windtunnel vacuum belt
There are 4 screws that you need to remove. The belt lies between the roller and a pin. With a little effort, you just pull out the roller, and the belt will come loose. When putting the new belt, you need to insert the belt into the pin first and then put the other end of the belt onto the roller. Then pull the roller and put it back into its groove. Voila!
Aug 19, 2008 | Vacuums
Savvy vacuum belt
It is easier when you also take the top off. Then you can put the belt over the roller and re-install it, then put the bottom plate back on, then turn it over, undo the motor and put the belt on the motor pulley, re-install the motor and put the rest back together. To remove the top, thewre are a couple of scres from the bottom, then from the top, remove the Hoover emblem, there is a screw there to remove and the top will come off.
Jul 11, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Vacuums Logo
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
