Question about GE Profile PDW9880NSS Stainless Steel Dishwasher
Dishwasher won't stop beeping
My GE Profile Quiet Touch II just started beeping with the Normal Wash light flashing. I can't get it to stop. Reset does nothing. Any ideas??
  • 97 Answers
SOURCE: NORMAL Wash light is blinking and I can't CANCEL
turn unit off at the breaker box. let sit for 5mins and turn back on. will usually reset board. be sure door is closing completly. could be a door switch.
Posted on Jun 09, 2009
We had the same issue with ours...tried turning off at the breaker, still didn't reset. Contacted appliance repair who came in and unplugged it from underneath the sink, waited a few seconds and plugged it back...dishwasher reset and repairman charged trip charge and labor $65 BUT problem is resolved and we now know what to do in the future.
Posted on Oct 18, 2009
SOURCE: dishwasher door lock does not unlock on my GE quiet profile 3 dis
Sounds like you door safety interlock switches, are faulty, these can be easily replaced, at reasonable cost.
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=replace-door-switch
http://www.rd.com/how-to-repair-a-dishwasher/article18243.html
http://www.ehow.com/how_5676347_replace-door-switch-dishwasher.html
A DIY links above. it is pretty easy, you may even be able to adjust your one too.
Posted on Apr 06, 2010
tbirdfan1
  • 3051 Answers
SOURCE: My dishwasher GE profile quiet power II MV832134B
Hello there again
I think we got disconnected in the chat room so i will post the solutions here for you to check ok
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt If the motor isn't turning or working, the unit won't drain. at all." If the motor hums but doesn't turn, it may need to be replaced.
Posted on Jun 27, 2010
SOURCE: My GE Profile Quiet Power II Dishwasher is leaving
First thing to check is to make sure that the "jet holes" are clear on all the water arms.
Posted on Mar 13, 2011
My GE Quiet Power 1 is constantly beeping when you press Normal wash, and then just flashing when you press Start/Reset.
Try cutting power to it at breaker box and see if electronics will reset. If not, sounds like a control board problem
Nov 11, 2017 | GE Dishwashers
Whirlpool Quiet Wash II
there might be connection problem with those buttons you've tried
Jun 04, 2013 | Dishwashers
My GE quiet power 1 dishwasher has flashing lights and won't stop cycling, what do i do?
I have had this problem with this dishwasher in my rented apartment occasionally since I moved in. It would usually reset itself if I let it sit a while, but not today. Today all it would do is flash and beep and I finally just unplugged it. I stumbled across this page and read the post by Dyons above and it worked. Close the door, let it grind away and within 2 minutes it will reset itself. Thanks, Dyons!!!
Sep 28, 2011 | GE Dishwashers
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
NORMAL Wash light is blinking and I can't CANCEL wash. GE Quiet Power II PROFILE dishwasher. Started a normal wash and a few minutes into it the NORMAL light started blinking and can't find a way to reset.
Jun 09, 2009 | GE Dishwashers
GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
May 10, 2009 | GE Dishwashers
GE Profile PDW9880NSS Stainless Steel Dishwasher Logo
234 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
