Question about Nokia 3310 Cellular Phone
Reconnect charger nokia 3310
Hi bro,would you show me the right way for jumpering nokia 3310 not charging.thanks...
Do this sir ur problem will be ok.
Posted on Jul 10, 2008
  • julhian01 Jul 10, 2008
    do this sir 100% tested. enjoy
I have nokia 3310 mobile i connect the charger and then mobile say reconnect charger pls solve my problam...
Possible that the charger is deficient in voltage and so is not delivering the required current for the battery to charge. You need to use a multimeter to check the charger, connect and measure the voltage at the battery terminal on the phone. It can also be a weak battery or shorted battery they can also show the symptom of no charging.
Ideal to get another charger battery from a friend to confirm before you buy one.
Mar 30, 2011 | Nokia 3310 Cellular Phone
Tip
I used a standard 3310 type Nokia charger. The charging plug has a small hole...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on May 21, 2008 | T-Mobile MDA
Dear sir my nokia 1600 not charging
there are few options by which this problem may rise .
* Old battery will not charge if its bulged. so get new 1 * Check if the charging plug in side th mobile has not broken. * There mite be a short connection with the pin which will not charge the battery. * take battery out keep it in sun for 5 mins and use it.or rub in 1 direction. mite work. * If there is a problem with the board , check below not-charging-1-300x203.jpg
1600 Not Charging Problem
1600 Not Charging Problem 1
1600 Not Charging Problem 2
1600 Not Charging Problem 3
Thanks for the ratting Good luck
Dec 22, 2010 | Nokia 1600 Cellular Phone
Hey i am unable to charge and on my mobile nokia 3310
The phones Charging IC is damaged,
If you allready tried another battery and another charger.
to fix charging IC contact Nokia service
May 09, 2010 | Nokia 3310 Cellular Phone
Is not charging
you need a right charger, so dat will charge!
Mar 21, 2010 | Nokia 3310 Cellular Phone
Nokia 3310 charger.. won't charge help me..
if its the car charger check the cigarette lighter fuse and also the charger fuse
Sep 25, 2009 | Nokia Car Charger: 3310 3360 3390 3395...
Battery Types
Yes that is software problem, you need to reflashing phone firmware. Some tools and Software you need ; Nokia Flasher cable, Nokia tool Software, Nokia flasher software, a proper Nokia Firware ( NHM-5)
Feb 06, 2009 | Nokia 3310 Cellular Phone
Problem with Nokia 3310
If the battery was draining too quickly, and a new battery does the same thing, it is very possible that the phone has a defect that is causing it to draw too much currnet. This you will not be able to service yourself. You will have to send the phone out for service.
Considering the cost of servicing a phone, it may be worth to simply get a new phone.
Jerry G.
Jul 05, 2008 | Nokia 3310 Cellular Phone
3310 not show charging
check the charging tracks
Sep 08, 2007 | Nokia 6233 Cellular Phone
Nokia 3310 Cellular Phone Logo
1,303 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
