Question about RCA HD52W59 HDTV Projection Television
Blinking light ptoo ing sound
We have replaced the fly back transformer the new one has a seperate spot for the focus and screen wire the old one had a single spot do I need to run a jumper between the two or is it something eles please help..
  • 3 Answers
Small wire goes in the small hole on top of flyback
hv wire goes in the hole on the left of that hole
Posted on Jul 02, 2008
Led light keeps blinking tv turns on then turns off
sound like fly back transformer is acting up or screen voltage is abnormal.
Jun 13, 2011 | Sony FD Trinitron WEGA KV-32HS420 32" TV
No picture but the red power button blinks each time it blinks there is a thumping noise from speakers and a clicking sound
try checking the fuse area, together with the capacitor & resistor may one of them is faulty. and also check for any bad soldered.
let me know
Oct 31, 2008 | Haier HTF27R11 27" TV
My Television problem is that when you press on the power button you hear sound but no picture on the screen but the noise you hear is not the sound like people talking . I when to a technician an he...
The problem arises from the fly back transformer not converting enough current to be used by your TV. This fault might have cause some other components to malfunction. I would advice you replace the fly back transformer immediately, as a first approach. Thanks
Apr 21, 2011 | Sanyo DS31590 31" TV
Can not adjust screen to see what channel or video i have it on
if the screen is out of focus this is likely due to a defective fly-back transformer, or focus control circuitry.
Jan 30, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Power light blinks on and off. No picture and no sound
ur high voltage is dead.The FBT,The fly back transformer is dead.The big block of plastic with a red wire with a cap hook to the CRT(the tv tube).
Sep 11, 2009 | Televison & Video
Tv will not turn on, just makes a clicking sound
Brother this is problem usually  when either the fly-back (picture tube transformer )or tube  voltage regulator  Transistor is damaged or the picture tube has a short
Best of luck
Aug 12, 2009 | Panasonic Televison & Video
RCA HD27F754T 1 Solid Red Light, then, 10 Blinking Red Lights
HI. this may be a fly back situation. this is a transformer that is located on the power board section of your set. This device stores and, distributes the necessary AC current needed for proper CRT performance. There is also a horizontal deflection chip that will shut off the transformer if it becomes unstable as well.
I recommend checking the Horizontal deflection chip for damage. if this chip is in good condition, replace the HV Fly back transformer.
Jun 26, 2009 | RCA 27F650T 27" TV
Rear projection tv picture blurry
HELLO sounds like you need to adjust the focus pod on the fly back transformer. not the screens but the focus on the fly back transformer to see if that clears up the picture. hope this helps. "GOOD LUCK"
Aug 09, 2008 | Televison & Video
Panasonic Flat Screen Model No. CT36HX42F won't turn on
the 2SC5612 transistor near the fly back transformer is shorted
Mar 31, 2008 | Televison & Video
Colors are distorted, brightness excessive
You may have a bad Fly Back transformer. The focus and screen(brightness) controls are located on this transformer. Some of the new RCA's have had problems with this transformer. If the screen control opens up the picture may either go dark or light which would cause your problem. Also a bad Picture tube could cause this. It shouldn't since the tv is not very old though. I've seen a few new ones go bad. Stargazer
Jan 29, 2007 | RCA 35V432T 35" TV
RCA HD52W59 HDTV Projection Television Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
