I just finished replacing the ADF motor assembly (Part 2132225 from Compass Micro). It is somewhat tricky. You need to download the service manual via the link in the adjacent solution. There are 2 screws to remove the plastic housing and then 2 more to loosen the motor unit. It is very easy to knock loose the little plastic gears as you try to remove the motor unit. Make sure you pay attention to where they go so you can replace them. Then you have to pass the cable all the way to the corner of the lid and down to the main board hook up. There is a plastic fastener for the cover over the main board that you have to bisect to lift the panel for access. Make sure you seat the motor assembly firmly and make it very tight when you screw it back together.
SOURCE: Im going to purchase an
Navigate HERE! ..and click on "Click here to start download.." save the service manual for Epson Artisan 800 (disassembly procedures)
SOURCE: Epson Artisan 800...adf keeps saying paper jam,
ADF Motor Assembly has gears which crack. Replacement of ADF Motor Assembly normally required. Compass Micro Inc sells this part. Part #: 2132225.
