Question about D-Link AirPlus DI-524 Wireless Router
My d-link wireless is not working
I have two laptops with wi/fi and one laptop with the d-link card and for some reason we can't get on to the internet. could the router be toast. i writing to you on my desk top which work on the eithernet cord. what to do?
  • 148 Answers
Question: Can no one get connected to the router?
If the answer is yes then you will have to default the router to the factory specifications To do this get a very small paper clip and locate the small hole in the back of the router. Unplug the router.. then insert the clip in the pinhole and hold it down.. you will feel it click.. do this for 30 seconds.. remove the clip for fifteen the clip and at the same time while holding the button down plug in your router and continue to hold the clip in for thirty seconds. Remove the clip and wait for five minutes while the router re-boots. You should be able to get on now. Let me know if this worked.. if it did not there is another route..Take care.. Be mucho blessed...Mark
Posted on Jun 29, 2008
DELL Latitude E6510, wifi button was OFF, now it is not working.Wifi is showing red cross. Please help how t0 turn it ON? I think it is Hardware issue. Can I fix it through Windows? Windows 7
Information Technologies
Enable / Disable an Enterprise Laptop's Wi-Fi
Wi-Fi, short for Wireless Fidelity, is networking technology that allows you to connect to the Internet. If you have a wireless-enabled Latitude computer you can connect to the Internet when in range of an access point called a hotspot.
When not in use your Latitude's wireless card should be disabled. By disabling Wi-Fi, you will receive two benefits:
Start-up times will be much faster.
If the wireless card is ON and you are out of the office (not connected to your normal, wired connection), the laptop will try to use the Wi-Fi network during the login process to run the various start-up scripts, etc. It will eventually time-out (fail). By having the wireless card turned OFF, the start-up process will be much faster.
Computer will not continually search for a wireless network (and waste battery life).
If you are in the office (connected to your normal, wired connection) or in a location where there is no wireless hotspot, you don't need to have the computer waste processing power by looking and looking for a wireless hotspot. By disabling Wi-Fi, you will gain a little more power for your other tasks. In addition, you will maximize your battery operating time by disabling wireless activity.
NOTE: After your Latitude has started up completely, you can ENABLE the wireless card and connect to a wireless hotspot. For example, a wireless router at your home or at a local coffee shop. If you have connected to this hotspot previously, the wireless card should connect automatically for you.
NOTE: Once you have the wireless card enabled, before you shut down the computer, you should again DISABLE the card. The computer will then be ready for the next time you turn it on with wireless turned off.
Enable / Disable with Hardware Switch
The more recent Latitude models have a wireless switch to enable or disable wireless network devices and the
Wi-Fi Catcher Network Locator.
Dell Latitude E6420 and E6520 Series
These laptops have a small switch on the RIGHT side of the keyboard. The switch is toward the front of the laptop. The Wi-Fi Catcher™ icon will is above the keyboard. You will see a lit radio tower if the wireless switch is enable
Oct 17, 2016 | Dell Latitude E6510 Notebook
No wireless working
enable it from the bios ,,, enable it pressing the wi-fi key ,,, replace the wireless card or switch the antenna cables connected to the wi-fi card ...
it would be much better if specified a model ,,,
Mar 06, 2012 | HP Pavilion 1137NR Notebook
I have a compaq presario F756nr with an Atheros wireless wi-fi card in it. Can I replace the wi-fi card with a Broadcom 802.11 b/g wireless LAN card?
no you cannot replace the built-in wi-fi card...
if you try to change the drivers for atheros wi-fi to Broadcam driver, your wi-fi card will not function anymore.... but you can always install another WI-FI card in your laptop... you can buy a USB Adapter or a Cardbus(PCMCIA) adapter for this purpose...if you want your wi-fi signal strenth and range to be higher, you can opt to buy an adapter which comes under N standard....N standard wi-fi adapters are capable of connecting at a speed of more than 300mbps(practically) to any N standard device like router....
Mar 29, 2010 | HP Compaq Presario F756NR Notebook
My wi fi is not working. How do I get it to work?
you go con device manager -> network adapter and check ur wireless have driver?? if have but dont work you change with new wireless and don't work that problem is from your motherboard because with hp dv6000 have a problem with chipset i meet case same to you
Jan 26, 2010 | HP Pavilion dv6000z Notebook
HP Pavilion dv9700 laptop, Wireless stops working at random.
It is because your wi fi network adapter not getting ip addresses from router.
For that connect your router to computer with ethernet cable then access it with following link.
type user name as "admin" and password as "admin" or blank or "password"
then go to advaced and enable DHCP .
Then save and restart router.
Then go to your laptop go to my etwork places proeprty then right click on your wi fi adapter then proeprty then tcp ip and set ip get automatic.
Then it works fine.
Let me know if you need more assistanse.
Sep 23, 2009 | HP Pavilion dv9000z Notebook
IBM ThinkPad T40 no LAN or internet connection
Fot that first you need wi fi router with intenret connection .
Then check in your laptop that your wi fi network adapter driver are installed.
Also check its wi fi switch is turn on it is on laptop.
Check your wireless in router is enabled.
also check your wi fi network adapter is enabled in your LAPTOP.
Let me know if you want to configure your router and if you need more assistanse .
Aug 26, 2009 | IBM ThinkPad T40 2373 Notebook
Getting wireless to work on my Dell Inspiron 1000
find switch on laptop it is wi fi network adapter switch on laptop turn on it.
Then also check your wi fi drivers are installed.
if driver are not install for wi fi downlaod from here in netwrok
then install wi fi then check.
Jul 14, 2009 | Dell Inspiron 1000 Notebook
Wi-fi card on Win98SE laptop not allowing internet to connect.
I really believe this is some kind of driver error. You must first remove the existing driver and then install the following driver.
If that doesn't work we're gonna have to try messing with the wireless router settings.
May 26, 2009 | D-Link AirPlus Xtreme G DWL-G650 108Mbps...
Gateway PC crashing when connecting to Wi-FI
if i was you i would load up a version of win xp on another hard drive inserted into your laptop, load the drivers for the laptop including wi fi drivers then see if ok. if not you can be sure its a faulty wi fi card in your laptop,you need to disable internal wi fi card remove,replace it.but first try borrow a pcmcia wi fi card just to check if everythings ok
Dec 06, 2008 | Gateway MX6438 Notebook
What do I need to get for mobilepro 900 to get on internet
Got the model, could you tell me more about your PDA?
Nov 21, 2007 | Computers & Internet
D-Link AirPlus DI-524 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
